[Qgis-user] Verifying QGIS
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Mon Nov  4 23:23:12 PST 2024
> David Saldivar davidmsaldivar03 at gmail.com
> Mon Nov 4 14:25:22 PST 2024
> I have been having trouble with getting QGIS up and running. I am able to
> get it downloaded however it says that it can not be verified. I have
> attached a screenshot of this below
Hi David,
did you already follow the instruction provided in the macOS section of
the Download page available on the QGIS Web site at
https://qgis.org/download ?
Tips for first launch
After installing QGIS, the first launch attempt may fail due to Apple’s
security framework.
For macOS Sonoma and earlier: To enable QGIS, command-click on its icon
in your Applications folder and select Open in the context menu. A
confirmation dialog will display where you need to click the Open button
again. This only has to be done once.
For macOS Sequoia and newer: To enable QGIS, command-click its icon in
your Applications folder and select Open from the context menu. A
warning dialog will appear; click the Done button. Next, navigate to
System Settings > Privacy & Security and scroll to the Security section.
You should see a message stating that “QGIS” was blocked to protect your
Mac. Click Open Anyway. A confirmation dialog will appear; click Open
Anyway again. This only has to be done once.
Regards.
Andrea
More information about the QGIS-User
