[Qgis-user] volume calculation workflow.
Byron Veilleux
byron at conjugategeo.com
Mon Nov 11 17:15:01 PST 2024
i have a shapefile with elevation values as digitized contours, for the
same surface, i have well data elevation points for this same surface.
is it possible in QGIS to use the contours and well points to create a grid?
once i have created grids (actually two surfaces), is there a way to
subtract these grids and calculate the volume between these surfaces?
is there a tutorial for grid operations such as subtracting one grid from
another to calculate volumes and multiply grids together or using constant
values
thank you
Byron Veilleux, MSc. P.Geo
Conjugate Geologic Services Limited
Calgary, Alberta Canada
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241111/7f8906f5/attachment.htm>
More information about the QGIS-User
