[Qgis-user] volume calculation workflow.
Emma Hain emma at north-road.com
Tue Nov 19 20:15:33 PST 2024
Does this help?
https://qgis-in-mineral-exploration.readthedocs.io/en/latest/source/geological_data/grid_layout.html
On Tue, 12 Nov 2024 at 11:15, Byron Veilleux via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> i have a shapefile with elevation values as digitized contours, for the
> same surface, i have well data elevation points for this same surface.
> is it possible in QGIS to use the contours and well points to create a
> grid?
> once i have created grids (actually two surfaces), is there a way to
> subtract these grids and calculate the volume between these surfaces?
> is there a tutorial for grid operations such as subtracting one grid from
> another to calculate volumes and multiply grids together or using constant
> values
> thank you
> Byron Veilleux, MSc. P.Geo
> Conjugate Geologic Services Limited
> Calgary, Alberta Canada
> byron at conjugategeo.com
> Cell:4037108414
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Emma Hain — Product Manager/Senior GIS Analyst
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241120/bc99e176/attachment.htm>
More information about the QGIS-User mailing list
