[Qgis-user] volume calculation workflow.
kirk
kirk at nortekresources.com
Wed Nov 20 04:26:48 PST 2024
Hi ByronThe answer is yes. Create your 2 grids using the vector to radtor tools within qgis or saga and then use grid calculator to obtain the difference between the two.Kirk SchmidtSent from my Galaxy
-------- Original message --------From: Emma Hain via QGIS-User <qgis-user at lists.osgeo.org> Date: 2024-11-20 12:15 a.m. (GMT-04:00) To: Byron Veilleux <byron at conjugategeo.com> Cc: qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] volume calculation workflow. Does this help?https://qgis-in-mineral-exploration.readthedocs.io/en/latest/source/geological_data/grid_layout.htmlOn Tue, 12 Nov 2024 at 11:15, Byron Veilleux via QGIS-User <qgis-user at lists.osgeo.org> wrote:i have a shapefile with elevation values as digitized contours, for the same surface, i have well data elevation points for this same surface. is it possible in QGIS to use the contours and well points to create a grid?once i have created grids (actually two surfaces), is there a way to subtract these grids and calculate the volume between these surfaces?is there a tutorial for grid operations such as subtracting one grid from another to calculate volumes and multiply grids together or using constant valuesthank you-- Byron Veilleux, MSc. P.GeoConjugate Geologic Services LimitedCalgary, Alberta Canadabyron at conjugategeo.comCell:4037108414
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
-- Emma Hain — Product Manager/Senior GIS Analyst
emma at north-road.com
North RoadCartography • Development • Spatial Analysis
north-road.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241120/afcad3a0/attachment.htm>
More information about the QGIS-User
