[Qgis-user] USGS 3DEM question: export to kml/kmz
Bernie Connors bernie.connors at unb.ca
Wed Nov 13 19:03:20 PST 2024
Here is a suggestion. Keep the USGS DEM tif in QGIS and symbolize it as a
hillshade.  It will be very easy to spot abandoned railways in the
hillshade.  Then use the Quick Maps plugin to add the Google Satellite map
to QGIS.  You can easily switch back and forth between Google Satellite
layer and the USGS DEM hillshade.
Cheers,
Bernie.
On Wed, Nov 13, 2024, 10:11 p.m. John W. Blue via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Thanks for the file composition info.
> Using that I was able to convert the downloaded 3DEM .tif from a raster to
> vector using Raster > Conversion > Polygonize (Raster to Vector) option.
> The resultant exported .kml file size was almost 1 Gb and while Google
> earth was to load it, it was nothing but a white square.
> I did find that Raster > Analysis > Hillshade was able to produce some
> remarkable and useable results.  What is strange is that the conversion of
> the hillshade raster to vector .kml never completes.  It quickly gets to 7%
> and then seemly stalls out.
> Am I not waiting long enough?
> John
> From: oisin.kelly.wild at gmail.com [mailto:oisin.kelly.wild at gmail.com]
> Sent: Tuesday, November 12, 2024 3:01 PM
> To: John W. Blue
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] USGS 3DEM question: export to kml/kmz
> The tif file is a raster.
> Kml is a vector format.
> You need to use one of the processing tools to extract contours or spot
> heights and then export the results to kml.
> Get BlueMail for Android
> On 12 Nov 2024, at 20:06, "John W. Blue via QGIS-User" <
> Hello,
> QGIS newbie here.  I want to use USGS LiDAR to search for abandoned
> railroad grades as a layer in Google Earth.
> I am able to download the 1 meter tif from USGS and I am able to add it as
> a layer in QGIS.  I cannot, however, figure out how export the layer as a
> kml/kmz file.
> I right-click on the layer and choose “Export” and then “Save As” followed
> by dropping the “Format” menu down.  Heaps and heaps of options to choose
> from but none for kml/kmz.
> Any help in what I am missing or doing wrong would be appreciated.
> John
> ________________________________________
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241113/ad1380f5/attachment.htm>
More information about the QGIS-User mailing list
