[Qgis-user] USGS 3DEM question: export to kml/kmz
    John W. Blue
    john.blue at rrcic.com
    Wed Nov 13 06:32:32 PST 2024
Thanks for the file composition info.
Using that I was able to convert the downloaded 3DEM .tif from a raster to vector using Raster > Conversion > Polygonize (Raster to Vector) option.  The resultant exported .kml file size was almost 1 Gb and while Google earth was to load it, it was nothing but a white square.
I did find that Raster > Analysis > Hillshade was able to produce some remarkable and useable results.  What is strange is that the conversion of the hillshade raster to vector .kml never completes.  It quickly gets to 7% and then seemly stalls out.
Am I not waiting long enough?
John
From: oisin.kelly.wild at gmail.com [mailto:oisin.kelly.wild at gmail.com]
Sent: Tuesday, November 12, 2024 3:01 PM
To: John W. Blue
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] USGS 3DEM question: export to kml/kmz
The tif file is a raster.
Kml is a vector format.
You need to use one of the processing tools to extract contours or spot heights and then export the results to kml.
Get BlueMail for Android
On 12 Nov 2024, at 20:06, "John W. Blue via QGIS-User" <qgis-user at lists.osgeo.org> wrote:
Hello,
QGIS newbie here.  I want to use USGS LiDAR to search for abandoned railroad grades as a layer in Google Earth.
I am able to download the 1 meter tif from USGS and I am able to add it as a layer in QGIS.  I cannot, however, figure out how export the layer as a kml/kmz file.
I right-click on the layer and choose “Export” and then “Save As” followed by dropping the “Format” menu down.  Heaps and heaps of options to choose from but none for kml/kmz.
Any help in what I am missing or doing wrong would be appreciated.
John
________________________________________
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User
