[Qgis-user] CSV of outcrop locations loading error
Byron Veilleux
byron at conjugategeo.com
Tue Nov 26 12:54:34 PST 2024
i have attached a csv file of several points with 2 simple text labels to
accompany the x, y positions.
when i import this file, i try to import in DMS decimal format. i specify
column 2 as the x and column 3 as the y. when it imports, it puts the
points in the wrong spot. the x column becomes y and the y columns is
completely in error. this should be a fairly simple import, can
you please tell me how i can get this file to import properly. i was
importing into WGS 84 so that should not be the issue.
Byron Veilleux, MSc. P.Geo
Conjugate Geologic Services Limited
Calgary, Alberta Canada
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241126/fc03c40c/attachment.htm>
Name: devonian outcrop locations.csv
Type: text/csv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241126/fc03c40c/attachment.csv>
More information about the QGIS-User
