[Qgis-user] CSV of outcrop locations loading error
Randal Hale
rjhale at northrivergeographic.com
Tue Nov 26 13:30:39 PST 2024
Try this:
X field is Long
Y field is lat
Don't click DMS - leave unchecked.
Click add and see if those now line up where they need to line up. I
tossed an OSM map up there and I'm assuming these are road outcrops - so
I feel mostly good about the import.
Randy
On 11/26/24 15:54, Byron Veilleux via QGIS-User wrote:
> i have attached a csv file of several points with 2 simple text
> labels to accompany the x, y positions.
> when i import this file, i try to import in DMS decimal format. i
> specify column 2 as the x and column 3 as the y. when it imports, it
> puts the points in the wrong spot. the x column becomes y and the y
> columns is completely in error. this should be a fairly simple
> import, can you please tell me how i can get this file to import
> properly. i was importing into WGS 84 so that should not be the issue.
> Byron Veilleux, MSc. P.Geo
> Conjugate Geologic Services Limited
> Calgary, Alberta Canada
> byron at conjugategeo.com
> Cell:4037108414
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North Rivergeographic Systems, Inc
https://www.northrivergeographic.com
https://www.qgis-us.org
I hope this email finds you in the mountains, and as sun peeps through the trees the squirrels begin foraging.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241126/a1515297/attachment.htm>
More information about the QGIS-User
