[Qgis-user] CSV of outcrop locations loading error
Fernando M. Roxo da Motta petro at roxo.org
Tue Nov 26 13:31:44 PST 2024
On Tue, 26 Nov 2024 13:54:34 -0700, Byron Veilleux via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> i have attached a csv file of several points with 2 simple text
> labels to accompany the x, y positions.
> when i import this file, i try to import in DMS decimal format.  i
> specify column 2 as the x and column 3 as the y.  when it imports, it
> puts the points in the wrong spot.  the x column becomes y and the y
> columns is completely in error.   this should be a fairly simple
> import, can you please tell me how i can get this file to import
> properly.  i was importing into WGS 84 so that should not be the
> issue.
  According to the first line, the second line seems to be Latitude (Y)
and the third the Logitude (X).    The coordinates loos like decimal
degree instead of DMS.
  I opened the file in QGis stating comma as separator, decimal degree,
Y the Lat column and X the Long column.   Just used WGS 84 as CRC.
The points appear locate to the west of Calgary.
  HTH.
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
                PU5RXO | PX5Q6048                       | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
More information about the QGIS-User mailing list
