[Qgis-user] CSV of outcrop locations loading error
kirk kirk at nortekresources.com
Wed Nov 27 00:07:16 PST 2024
Hi Byron:This is a common mistake when working with lat/long.  Your x value should be longitude and latitude should by y. Kirk SchmidtSent from my GalaxySent from my Galaxy
-------- Original message --------From: Byron Veilleux via QGIS-User <qgis-user at lists.osgeo.org> Date: 2024-11-26  4:02 p.m.  (GMT-05:00) To: Qgis-user at lists.osgeo.org Subject: [Qgis-user] CSV of outcrop locations loading error i have attached a csv file of several points with 2 simple text labels to accompany the x, y positions. when i import this file, i try to import in DMS decimal format.  i specify column 2 as the x and column 3 as the y.  when it imports, it puts the points in the wrong spot.  the x column becomes y and the y columns is completely in error.   this should be a fairly simple import, can you please tell me how i can get this file to import properly.  i was importing into WGS 84 so that should not be the issue.-- Byron Veilleux, MSc. P.GeoConjugate Geologic Services LimitedCalgary, Alberta Canadabyron at conjugategeo.comCell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241127/86043d69/attachment.htm>
More information about the QGIS-User mailing list
