[Qgis-user] Shapefile symbology no longer working when zoom in
    Karl Magnus Jönsson
    Karl-Magnus.Jonsson at kristianstad.se
    Thu Nov 28 06:58:46 PST 2024
Hi!
Which old version are you migrating from? Could be worth trying some intermediate version of QGIS. Open and save and then go to 3.40.
Kind regards
Karl-Magnus Jönsson
Från: QGIS-User <qgis-user-bounces at lists.osgeo.org> För Richard McDonnell via QGIS-User
Skickat: den 28 november 2024 15:07
Till: Andrew Chapman <andrew.chapman at donkagen.co.uk>; qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Shapefile symbology no longer working when zoom in
Hi Andrew,
Sounds like you have set Scale Dependant Visibility, setting a Min or Max Scale in the Symbology or Rendering on the Layer Properties
That would be my first port of call anyway.
Kind Regard's,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Andrew Chapman via QGIS-User
Sent: 28 November 2024 13:38
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Shapefile symbology no longer working when zoom in
I've not used QGIS for a number of years and now returned to version 3.34.0. With projects that worked ok with earlier versions I find that some shapefiles now only partially work when I zoom in. Text labels continue to work but sybology markers (point and line) vanish when I zoom to scales below about 1:10000.
I've tried Vector->Geometry Tools->Check Validity but the problem still exists.
Any suggestions?
Andrew Chapman
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241128/8ae7690e/attachment.htm>
More information about the QGIS-User
