[Qgis-user] Shapefile symbology no longer working when zoom in
Andrew Chapman
andrew.chapman at donkagen.co.uk
Thu Nov 28 09:05:17 PST 2024
Hi
My first thought has been Scale Dependant Visibility but I confirmed that
it was off. However, text displays ok when I zoom in but the symbology lines
or points vanish I dont think one could do this with SDV without two
instances of the same layer and different styling.
The suggestion of trying an earlier version of QGIS may be worth
investigating. Im returning to QGIS now because weve had very bad flooding
(again) but I havent been involved for the last five years due to health
issues. A wrecked computer and finding that all the backups hadnt been 100%
is rather complicating matters.
Ive found old QGIS setup exe files from 2013 and 2014 which I havent tried
to run yet as Im not sure if they would load an earlier version in parallel
with my later version.
Also, as the problem is associated with shapefiles, are there any
suggestions as to how then could be sanitised? It seems the problem files
are layers that I have created with earlier versions of QGIS while similar
aged ones that Ive downloaded from Ordinance Survey work fine.
Andrew
From: Karl Magnus Jönsson [mailto:Karl-Magnus.Jonsson at kristianstad.se]
Sent: 28 November 2024 14:59
To: Richard McDonnell; Andrew Chapman; qgis-user at lists.osgeo.org
Subject: Sv: [Qgis-user] Shapefile symbology no longer working when zoom in
Hi!
Which old version are you migrating from? Could be worth trying some
intermediate version of QGIS. Open and save and then go to 3.40.
Kind regards
Karl-Magnus Jönsson
Från: QGIS-User <qgis-user-bounces at lists.osgeo.org> För Richard McDonnell
via QGIS-User
Skickat: den 28 november 2024 15:07
Till: Andrew Chapman <andrew.chapman at donkagen.co.uk>;
Ämne: Re: [Qgis-user] Shapefile symbology no longer working when zoom in
Hi Andrew,
Sounds like you have set Scale Dependant Visibility, setting a Min or Max
Scale in the Symbology or Rendering on the Layer Properties
That would be my first port of call anyway.
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below
https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer:
https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andrew
Chapman via QGIS-User
Sent: 28 November 2024 13:38
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Shapefile symbology no longer working when zoom in
Ive not used QGIS for a number of years and now returned to version 3.34.0.
With projects that worked ok with earlier versions I find that some
shapefiles now only partially work when I zoom in. Text labels continue to
work but sybology markers (point and line) vanish when I zoom to scales
below about 1:10000.
Ive tried Vector->Geometry Tools->Check Validity but the problem still
exists.
Any suggestions?
Andrew Chapman
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241128/ed6682f2/attachment-0001.htm>
More information about the QGIS-User
