[Qgis-user] offline basemap in Qfield
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Mon Oct 14 07:00:03 PDT 2024
If you use www.merginmaps.com QGIS plugin, it will allow you to download
our own vector tiles generated from OpenStreetMaps using OpenMapTiles
schema for offline usage.
Kind regards
Saber
On Mon, 14 Oct 2024 at 14:59, Greg Troxel via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> "Huesmann, Michaela via QGIS-User" <qgis-user at lists.osgeo.org> writes:
> > I would like to record data with Qfield using my Android mobile
> > phone. In order not to use too much data volume, the base maps should
> > be downloaded via WiFi beforehand so that they can be used offline
> > outside. However, GPS must be used for orientation during the mobile
> > recording process. My questions about this:
> > 1. Which map material for Germany can be used offline as  base map in my
> qfield project and how can I download it?
> > 2. How do I ensure that the offline maps are used outside and that no
> download takes place while I navigate with GPS?
> You didn't explain
>   - How much data is too much?
>   - What happens in terms of data if you just use an OSM mapnik basemap
>     + in particualr, what if you open qfield on wifi and pan around to
>       all the places you are going to be, to cause it to fetch data.
>       Note that OSM requires that users of its tile service cache data
>       for a reasonable period of time (7 days?), and thus QField should
>       be caching.
>   - What size area you are operating in?
> I mean to ask "are you really sure you have a problem that needs
> solving?"
> It is straigthforward to make a raster image of a small area and use
> that via "copy" in the now-oddly-named "cable" export.  (I use nextcloud
> to exchange bits, not an actual cable...)
> Making something that can cover a larger area at varying resolution
> probably involves some sort of tiles-in-sqlite format.
> In general, the only map data that I'm aware of with licensing that
> permits this sort of use is OpenStreetMap, and in the US, government
> data from the federal government and a number of states.  (I have no
> knowledge.de, but I'd expect similar -- OSM and maybe government.)
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241014/5f8eb0e4/attachment.htm>
More information about the QGIS-User
