[Qgis-user] offline basemap in Qfield
Roland Berger
roland.berger at steinerpartner.com
Mon Oct 14 07:16:02 PDT 2024
There is also the concept of "Shared local datasets":
https://docs.qfield.org/how-to/outside-layers/?h=local
It is useful if you need the same dataset (orthophoto/basemap) in
different projects.
Kind regards
Roland
On 10/14/24 16:00, Saber Razmjooei via QGIS-User wrote:
> If you use www.merginmaps.com <http://www.merginmaps.com> QGIS plugin,
> it will allow you to download our own vector tiles generated from
> OpenStreetMaps using OpenMapTiles schema for offline usage.
> Kind regards
> Saber
> On Mon, 14 Oct 2024 at 14:59, Greg Troxel via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
> "Huesmann, Michaela via QGIS-User" <qgis-user at lists.osgeo.org> writes:
> > I would like to record data with Qfield using my Android mobile
> > phone. In order not to use too much data volume, the base maps
> should
> > be downloaded via WiFi beforehand so that they can be used offline
> > outside. However, GPS must be used for orientation during the mobile
> > recording process. My questions about this:
> > 1. Which map material for Germany can be used offline as base
> map in my qfield project and how can I download it?
> > 2. How do I ensure that the offline maps are used outside and
> that no download takes place while I navigate with GPS?
> You didn't explain
> - How much data is too much?
> - What happens in terms of data if you just use an OSM mapnik
> basemap
> + in particualr, what if you open qfield on wifi and pan around to
> all the places you are going to be, to cause it to fetch data.
> Note that OSM requires that users of its tile service cache data
> for a reasonable period of time (7 days?), and thus QField
> should
> be caching.
> - What size area you are operating in?
> I mean to ask "are you really sure you have a problem that needs
> solving?"
> It is straigthforward to make a raster image of a small area and use
> that via "copy" in the now-oddly-named "cable" export. (I use
> nextcloud
> to exchange bits, not an actual cable...)
> Making something that can cover a larger area at varying resolution
> probably involves some sort of tiles-in-sqlite format.
> In general, the only map data that I'm aware of with licensing that
> permits this sort of use is OpenStreetMap, and in the US, government
> data from the federal government and a number of states. (I have no
> knowledge.de <http://knowledge.de>, but I'd expect similar -- OSM
> and maybe government.)
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
> +44 (0)7568 129733
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
*Steiner & Partner Landschaftsarchitektur GmbH**
*Roland Berger - Geschäftsführer Stv.
Waisenhausstrasse 2
CH-3600 Thun
Mobile: +41 79 709 56 89 <tel:+41%2079%20709%2056%2089>
Tel: +41 33 335 76 53 <tel:+41%2033%20335%2076%2053>
www.steinerpartner.com <http://www.steinerpartner.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241014/2bec2233/attachment-0001.htm>
More information about the QGIS-User
