[Qgis-user] [E3] Inquiry regarding the name of the coordinate system, EPSG:5186
    Even Rouault
    even.rouault at spatialys.com
    Thu Oct 17 20:44:16 PDT 2024
Dear Dongguk Lee,
interesting topic! I just did a bit of "geodetic archeology" and I
figured out from
https://github.com/Esri/projection-engine-db-doc/blob/440e9f0e7184ce00b567cf6531d54d8c15d24ed8/objedit/gxyzcs_syn.txt#L127
, that "Korea_2000" was an older name used by ESRI a few years ago for
what EPSG now calls "KGD2002".  Ideally PROJ (the library used
underneath by QGIS to manage coordinate systems) should store this alias
somewhere, but it doesn't currently
Anyway you can safely use EPSG:5186 for shapefiles with a
KGD200_Central_Belt_2010 .prj. This is just the same CRS.
Even
Le 18/10/2024 à 05:16, "이동국" via QGIS-User a écrit :
> To Whom It May Concern,
> My name is Dongguk Lee and I work for a GIS company, called Ethree, in South Korea. We have been using QGIS since around 2020 and have been working on many GIS projects during this time. However, we recently discovered that the data we have collected and analyzed seems to be in a different coordinate system. Upon comparing the projection details in the .prj files, we noticed that they are nearly identical except of the name of the coordinate system, but we are unsure if there has been a change in naming due to updates of the software. Could you please share any information on this issue if you have?
> Our specific question is whether "KGD200_Central_Belt_2010" from a new version and "Korea_2000_Korea_Central_Bult_2010" from an old version are different. We have been using the EPSG:5186 system all the time.
> Please check the attached photo showcasing the difference (the top one
> is new while the botton one is old)
> I apologize for the length of this email and
> appreciate any assistance you can provide.
> Best regards,
> Dongguk Lee
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241018/c357b4b7/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20241018/c357b4b7/attachment-0001.jpeg>
More information about the QGIS-User
