[Qgis-user] seeing coordinates in the data table
    Greg Troxel
    gdt at lexort.com
    Mon Sep  2 12:37:58 PDT 2024
When I open the data table, I can't find a way to see the geometry
object, in either layer CRS or project CRS.
I do see a way to generate a layer which has the attributes as fields:
  https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#add-geometry-attributes
But I don't really  want to make a layer (which is a copy not a view).
I just want the data table to show me the geometry, because it is a
column and has a value.  (I don't mind that it is read only.)
Perhaps I should be using postgis and views to make a layer with extra
fields.  Any other advice?
More information about the QGIS-User
