[Qgis-user] seeing coordinates in the data table
    Andreas Neumann
    a.neumann at carto.net
    Mon Sep  2 12:53:46 PDT 2024
Hi Greg,
You can create a virtual column that shows the geometry values in a
human readable form. For points it is trivial. Just use $x and $y as
expressions, for other geometry types you can write out the WKT string.
https://docs.qgis.org/3.34/en/docs/user_manual/working_with_vector/attribute_table.html#creating-a-virtual-field
Hope this helps,
Andreas
On 2024-09-02 21:37, Greg Troxel via QGIS-User wrote:
> When I open the data table, I can't find a way to see the geometry
> object, in either layer CRS or project CRS.
> I do see a way to generate a layer which has the attributes as fields:
> https://docs.qgis.org/3.34/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#add-geometry-attributes
> But I don't really  want to make a layer (which is a copy not a view).
> I just want the data table to show me the geometry, because it is a
> column and has a value.  (I don't mind that it is read only.)
> Perhaps I should be using postgis and views to make a layer with extra
> fields.  Any other advice?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240902/89516af8/attachment.htm>
More information about the QGIS-User
