[Qgis-user] Generating maps automatically with specific geometries
Asim al-sofi asim56 at gmail.com
Tue Sep 3 01:53:02 PDT 2024
Hi all
Iam working on a project which needs to generate a lot of maps with
specific infrastructure of different locations.
I use WMS maps as background and generate a pdf of each location
automatically using QgsLayoutExporter.
The problem Iam facing is that I need to first generate the backgrounds of
each location (in pdf or png) and then use these backgrounds to generate
new maps with the
infrastructure and using the maps that belong to the location.
This takes a lot of time.
What I want is to automate the whole process by combining the geometry of
the infrastructure together with the background map and generate a pdf/png
directly.
So instead of 2 separate steps, i.e., generating backgrounds and then
adding them to the geometry.
Any ideas on how to tackle this problem?
Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240903/6d5eae10/attachment.htm>
More information about the QGIS-User mailing list
