[Qgis-user] Generating maps automatically with specific geometries
Nigel Berjak - General
nigel at s3.co.za
Tue Sep 3 02:30:34 PDT 2024
Hi Asim
May I ask why you can't include the geometry overlay with the background
WMS in a single output? If you need different layer combinations, then
using the Themes with Atlas and styled per rules, sounds like it would
achieve the same output.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-09-03 10:53, Asim al-sofi via QGIS-User wrote:
> Hi all
> Iam working on a project which needs to generate a lot of maps with
> specific infrastructure of different locations.
> I use WMS maps as background and generate a pdf of each location
> automatically using QgsLayoutExporter.
> The problem Iam facing is that I need to first generate the backgrounds
> of each location (in pdf or png) and then use these backgrounds to
> generate new maps with the
> infrastructure and using the maps that belong to the location.
> This takes a lot of time.
> What I want is to automate the whole process by combining the geometry
> of the infrastructure together with the background map and generate a
> pdf/png directly.
> So instead of 2 separate steps, i.e., generating backgrounds and then
> adding them to the geometry.
> Any ideas on how to tackle this problem?
> Regards,
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240903/7dec2b69/attachment.htm>
More information about the QGIS-User
