[Qgis-user] FW: "Phantom" point in created layer
Simon Dietmann
dietmann at pgnu.de
Wed Apr 2 00:31:55 PDT 2025
Hi Nôra,
maybe it´s a useful hint that the points are not somewhere in the ocean, but more or less exactly at the intersection of equator and prime meridian (0°/0°)?
Regards
Simon
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Nora Badenhorst via QGIS-User
Gesendet: Montag, 31. März 2025 08:29
An: Randal Hale <rjhale at northrivergeographic.com>; qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] FW: "Phantom" point in created layer
Hi Randy,
I used the “Add point” feature.
It is not stacked because the “phantom” points are all at the same location somewhere in the ocean.
Regards
Nôra Badenhorst
RESEARCH ASSISTANT AND OFFICE ADMINISTRATOR
nôrabadenhorst at nova.org.za<mailto:n%C3%B4rabadenhorst at nova.org.za>
+27 (0) 72 146 3633
Office 1, Aura Aesta Building, 2 Witteboom Street, Hartenbos 6520
nova.org.za<https://atpscan.global.hornetsecurity.com?d=HcD4B-lBhfMFa6aXh09rqTnKZdiFg11C7g6nNYQVrDs&f=puQscPhIWD1vvXjH1AvrwBiEaHzezkFJNo8fXLd-TWI&i=&k=ogqJ&m=RzFiodieeoML2_wZ6oBMIla2DLsMiv700yYpja7WO13K42-kjQ8d-Agyceyu4jq9AZMvc7ui67QArIXLNgC211cobe4DZlLdHu0UIOIJziYlIQLRg7mN3CJkMIdF-v6a&n=NoLdYU89BtkDjcpv2gAEwDNmG6xFtBfgMPHtV5gpJ0fmLheP-PN_mCENvsDrIe9a&r=VbrSZw12LsTyE0XDBlZ7Bg9TyAeMKUCmT9DuvT5zOGWZ05p_JShz8hMIN5Y8PiXO&s=eeff4e40fd3c842f573cf57255c45dd3ed8fc6f457482a9bffa9ffb437977dd7&u=https%3A%2F%2Fnova.org.za%2F>
Quality of life
begins at home
From: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Randal Hale via QGIS-User
Sent: Wednesday, 26 March 2025 14:50
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] FW: "Phantom" point in created layer
Good morning Nora (or afternoon) ,
I'm wondering if you select (draw a polygon using the select tool) around one or two points you might select 2 or 4 points - you may have points stacked accidentally.
Randy
On 3/26/25 02:14, Nora Badenhorst via QGIS-User wrote:
Hallo Chris,
Hope you are well??
Thanks for the reply.
Why are you using "Add polygon feature" when your goal appears to be adding points?
Sorry, I now realised that I wrote “polygon feature”. I actually use “Add point feature”
What is the geometry of your shapefile layer? If you intend to have points in it, then the geometry should be "point".
The geometry is Point.
Regards
Nôra Badenhorst
+27 (0) 72 146 3633
nova.org.za<https://atpscan.global.hornetsecurity.com?d=N-vJ7huDiBFZOajEG5N_CFWvPMXRiqilUW6uGKa-Ycc&f=gWFOEgBQAj-VWyI5Z-E6gGxB_j8KdxBgk8kbp-PaxGU&i=&k=iNNw&m=juosei-G-_8DLAeUoJzdafMOjbmM1JJAQrrZ5WFisFAZAVioH2AB2jOwulecJGOlbPquPIQmnIhwi1Bzv-FuyLgSxJbLxvDpmJvIGYe_G5vFct0GuJDLZKKB9YpDW9q2&n=n-bYWhdUKaavOBuXA_Kd7-sWDVDofYDqhOLMbZHkzzdP4Ezn6P9NK-UnmQeZ6bGy&r=URS0qldldmGCaSv5pgvzIDIMxlJ2rXZDQnFPfOPEO1CehPaVD7QwxIw7rc-b8dsq&s=e1cba59f823a8a797a2b6b9a3e82c3381f0c2e7ab6a0b1761896e3890f236036&u=https%3A%2F%2Fnova.org.za%2F>
Quality of life
begins at home
From: chris hermansen <clhermansen at gmail.com><mailto:clhermansen at gmail.com>
Sent: Tuesday, 25 March 2025 17:42
To: Nora Badenhorst <norabadenhorst at nova.org.za><mailto:norabadenhorst at nova.org.za>
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Nora and list,
On Tue, Mar 25, 2025 at 12:05 PM Nora Badenhorst via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
I am counting informal structures in our project areas.
I created a shapefile layer and use the “Toggle editing – Add polygon feature” function to add a point. Every structure gets a dot.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://atpscan.global.hornetsecurity.com?d=p86jpYIzd70DFMEw6K410AbPpSuDG4dyi7GMOgc8M8A&f=otpC1BU31ea6sI8OUhuk6qKmPRmOSs3nxyGf_LmietA&i=&k=738M&m=gVPWpKlKG9e8aW0aEzC1Tz4le6q3kB2R1rHgLNiSD8XobXRlELJoTvgplpiI4E-LosaPRaRcaEZ860uABm4QsnrQ1SEP2tbAeDpQ9m-63tCIytiQgfUqpbgSATK8BW6_&n=ZZjgfkRdlYqoiao6qRxYqBggu2iFrfa8xmBCWD7d3hHOm1frituvhpsMq5DoBY39&r=3sT1e9vvuPW7YEM_vJ8fsjFnaEoSkxVdM9-NRouLRMQljKCffvXQH-Zh2Ooa9AgB&s=3ce3e1f4dfdf2aa40720ee58d81c1f1ff0d2370093987461e58b2e3fdb9606f4&u=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://atpscan.global.hornetsecurity.com?d=5CoP5WSMcB45VwYyegfDdyfYFNgF_Yk9B1G9IDWyjKk&f=ErlYwwWIDtnkUDgpa9L6B082sKBd8Q2uTeqp8qCGfEY&i=&k=MOyd&m=Xjto4ryUw45BUdR_Cmfyd9-TcE-jefW5ir7sSfDRp-VOCo57m7rhUlamMg5T58u7FQohgYJ4Zl8g-LIspLKg8XgUQWQsUP22fQ1zM-88jKpdqGvQewRM3nl9f4r-FtbY&n=0R0yDm1IqtTi587lHtExgP_YKt7aAbmPUDgfdzxf9Eaj-fnJ1GOZ6brNtUGimUiq&r=-56_4AW12S4OpIGoQAYile1q-yQB2oYu3RQtmzlSu1znpJBHtOf-B6YRhXigxhci&s=52db350805f6a0af502fc08b5cfc0e5f0478cf5e0acab363e196d01cd291afac&u=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user>
Randal Hale
North Rivergeographic Systems, Inc
https://www.northrivergeographic.com<https://atpscan.global.hornetsecurity.com?d=t54Bw5ccblF3NvB83AqVPyzKpg2sULwI363w_gEqi18&f=HAhyh9YopvOEoZwcHslB-R_5j2gVzagfkVeGl2LwpBA&i=&k=Olrk&m=JFPR0thZAQ1k4VHVe6UHZ4oJ1WkjNrKBSx_3mu_BYm6WMRTkdeo1Qm12eVJfVQuY7_JDimvefp9C4bEtaD8C1Dh88hQz8sQeMS5nzjqbod3RmAe18S97yvAoloKI83iW&n=UDzMG3rN0lgTABXXBAS5wZrkLOIT-KUWgZhgkJdd88yw5wFfs2aQSBp0P-eCMzSD&r=vUKAxZxuQhQ7HbUtv3zIFQUh3o9g9GJU-pG5boRYb_vSoavcxye0Ukt8nIDkZfGs&s=054a5f4714b59c01bce214ff16170d9a385c70c8987e38ca5f679125e0a52b80&u=https%3A%2F%2Fwww.northrivergeographic.com>
https://www.qgis-us.org<https://atpscan.global.hornetsecurity.com?d=xaAKUnd8yrrveb_WEwoB2GCuXn78_pz_q2w2Qacn0nw&f=A701EsevKLykoWap9Aam3PxxTpk3nF8bvirPlFtQZio&i=&k=SE46&m=6p92UP9bC7bVNUmHaIXIYbBmYZ6ti03ybXv3N0rebH6X8gCPg3C3UctmmtEDGyEChwNomWPrlEd3EADkoUOkJNPvaJpUqqxFvCXYWUq5X6M50MV-ss4FqHjXSzqsonXA&n=pQXiJatfbuQqO4vXbrRUCVxOq0r1lwwlFyxdOKueKoQ63Zo8gEwXcJvAfsg8WUgy&r=GUm9iLhtPNz2YzCu8YTAsM3WqTEI7tCsNFc96Os6bkYiYY7dXx0VC75unELJO_XT&s=b7d06e5569efe58be312b17c9af4e625726f304096a178ee6b757e18ac19a531&u=https%3A%2F%2Fwww.qgis-us.org>
I hope this email finds you in the mountains, and as sun peeps through the trees the squirrels begin foraging.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250402/85395395/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250402/85395395/attachment-0001.png>
More information about the QGIS-User
