[Qgis-user] FW: "Phantom" point in created layer
Tobias Schula
geospatial at schula.org
Thu Apr 3 08:27:22 PDT 2025
Hi Nora,
On Thursday, 3 April 2025, 17:23:14 CEST Nora Badenhorst via QGIS-User wrote:
> I have created a NEW shapefile for each of my areas.
> Attached find one of these layers. It was created (geometry type: points)
> and saved. I then "edited" the layer and adding points using "add pint
> feature"
> When realising that there were "phantom" points, I selected the visible
> points and saved it as a new layer.
I imported your shapefile into QGIS 3.42.1, but I could not reproduce your
error. Adding points on your original just worked as expected, there were no
points without geometry created.
I'm sorry that I can't help you. Have you tried a recent version of QGIS and a
new profile? See if the error still persists if you start "from scratch", then
you try again with your old profile, and so on until you can hopefully find the
cause of the phantom points.
Best regards
Tobias A Schula
Forestry Expert
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250403/22a75636/attachment.sig>
More information about the QGIS-User
