[Qgis-user] FW: "Phantom" point in created layer
Nora Badenhorst
norabadenhorst at nova.org.za
Fri Apr 4 00:46:42 PDT 2025
Thanks for all your help.
Have a great day.
Best regards.
Nôra
Nôra Badenhorst
RESEARCH ASSISTANT AND OFFICE ADMINISTRATOR
nôrabadenhorst at nova.org.za
+27 (0) 72 146 3633
Office 1, Aura Aesta Building, 2 Witteboom Street, Hartenbos 6520
nova.org.za
Quality of life
begins at home
-----Original Message-----
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Tobias Schula via QGIS-User
Sent: Thursday, 03 April 2025 17:27
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] FW: "Phantom" point in created layer
Hi Nora,
On Thursday, 3 April 2025, 17:23:14 CEST Nora Badenhorst via QGIS-User wrote:
> I have created a NEW shapefile for each of my areas.
> Attached find one of these layers. It was created (geometry type:
> points) and saved. I then "edited" the layer and adding points using
> "add pint feature"
> When realising that there were "phantom" points, I selected the
> visible points and saved it as a new layer.
I imported your shapefile into QGIS 3.42.1, but I could not reproduce your error. Adding points on your original just worked as expected, there were no points without geometry created.
I'm sorry that I can't help you. Have you tried a recent version of QGIS and a new profile? See if the error still persists if you start "from scratch", then you try again with your old profile, and so on until you can hopefully find the cause of the phantom points.
Best regards
Tobias A Schula
Forestry Expert
geospatial at schula.org
More information about the QGIS-User
