[Qgis-user] QGIS 3.40 long term release
Clint Brayley
clinton.brayley at abl-group.com
Fri Apr 4 04:39:24 PDT 2025
Hi
Thank you , can I please confirm that once you have installed
[cid:image001.png at 01DBA55E.98086F00]
There should be no further update the version should always stay at 3.40.
Thanks
Clint,
-----Original Message-----
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Jürgen E. Fischer via QGIS-User
Sent: Friday, April 4, 2025 11:27 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 3.40 long term release
Hi Clint,
On Fri, 04. Apr 2025 at 09:57:37 +0000, Clint Brayley via QGIS-User wrote:
> I have installed QGIS 3.4 Bratislava as below.
> I installed it in c\:program files\q
> After a couple of hours the application then seems to install itself
> in a new folder "QGIS 3.42.1" and update itself as below.
> The original install location of the Q folder is not all but empty.
> I am looking to only use the QGIS 3.40 LTR version and nothing else.
> Please can I have some advice on how to prevent the application from updating itself?
It shouldn't do that. How did you install? On a silent install it might take
quite a while before "QGIS 3.42.1" is created and files appear.
So there's a chance that you thought the install was done, mistook an existing installation in Q with the new one that was still ongoing (the directories in Q should have a timestamp from install time).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Hi
Thanks
Clint,
Hi Clint,
Jürgen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/c4c0fa2b/attachment-0011.png>
More information about the QGIS-User
