[Qgis-user] QGIS 3.40 long term release
Jürgen E. Fischer jef at norbit.de
Fri Apr 4 03:26:46 PDT 2025
Hi Clint,
On Fri, 04. Apr 2025 at 09:57:37 +0000, Clint Brayley via QGIS-User wrote:
> I have installed QGIS 3.4 Bratislava as below.
> I installed it in c\:program files\q
> After a couple of hours the application then seems to install itself in a new
> folder "QGIS 3.42.1" and update itself as below.
> The original install location of the Q folder is not all but empty.
> I am looking to only use the QGIS 3.40 LTR version and nothing else.
> Please can I have some advice on how to prevent the application from updating itself?
It shouldn't do that.   How did you install?  On a silent install it might take
quite a while before "QGIS 3.42.1" is created and files appear.
So there's a chance that you thought the install was done, mistook an existing
installation in Q with the new one that was still ongoing (the directories in Q
should have a timestamp from install time).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250404/e594c28e/attachment.sig>
More information about the QGIS-User mailing list
