[Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
Krishna Konduru - VAL Krishna.Konduru at GUARD.com
Wed Apr 9 05:11:26 PDT 2025
Hi Bernie,
Yes, I added the 'Quick Map Services plugin' from Plugins section in QGIS through QGIS Official Plugin Repository. I choose Google Hybrid or OSM as my basemap. Google Maps layer is checked in the Layers section. Both the Project CRS and Layer CRS are in EPSG 3857. But still it's a blank screen. Don't know what to do.
Thanks,
Krishna Konduru
Berkshire Hathaway GUARD Insurance Companies
570-825-9900, ext.
From: QGIS-User on behalf of Bernie Connors via QGIS-User
Sent: Friday, March 28, 2025 06:31 PM
To: qgis-user at lists.osgeo.org
Subject: [EXTERNAL] Re: [Qgis-user] Unable to load Base maps in QGIS
CAUTION: This email originated from outside of BH Insurance.
Krishna, Are you using the Quick Map Services plugin? It is a fast and easy way to add a basemap to your QGIS project.https://plugins.qgis.org/plugins/quick_map_services/<https://plugins.qgis.org/plugins/quick_map_services/> Bernie. On Fri, Mar 28, 2025 at 7:33AM Patrick Dunford via QGIS-User <qgis-user at lists.osgeo.org> wrote:
[https://outlook.office.com/mail/AAMkADM0NTEyMzVhLTg4NTctNDYwOC05OGMyLWVlYmRlNTdiYmJkOAAuAAAAAAAW1Mt3PmJmT46Oyfwt75OjAQBRTO54I3kTQ6tXua0b1VbKAAAwTL0UAAA%3D/id/AAMkADM0NTEyMzVhLTg4NTctNDYwOC05OGMyLWVlYmRlNTdiYmJkOABGAAAAAAAW1Mt3PmJmT46Oyfwt75OjBwBRTO54I3kTQ6tXua0b1VbKAAAwTL0UAABRTO54I3kTQ6tXua0b1VbKAAAwTm0yAAA%3D?nativeVersion=1.2025.328.300]
CGBANNERINDICATOR
Krishna,
Bernie.
On Fri, Mar 28, 2025 at 7:33 AM Patrick Dunford via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
What is a "Base Map"?
A project has layers that are either loaded locally from file based sources, or remotely from some type of server (e.g. WMTS). The latter is subject to the assumption the owner of that server is willing to let you have access to the data you are attempting to connect to. In the case of both Google Maps and OSM, being the quoted examples, restrictions most certainly apply to connections to their servers. Such an issue would be irrelevant to this list since it would not be an issue caused by the Qgis software.
On 28/03/25 02:16, Krishna Konduru - VAL via QGIS-User wrote:
QGIS version: 3.34.15
I am able to load and see shape file layers. But I am unable to see/load base maps like OSM, Google Maps etc. in QGIS. Could someone please help me find the issue. I am unable to find one.
I tried restarting the software and system.
Layers boxes are also checked in Layers panel.
I tried mapping the same CRS between Project and Base map layer. Tried with both EPSG: 3857 and EPSG: 4326. But still not able to see them.
If anybody knows what the issue could be, please let us know.
Thanks,
Krishna Konduru
****** CONFIDENTIALITY NOTICE ******
THIS E-MAIL, INCLUDING ANY ATTACHED FILES, MAY CONTAIN CONFIDENTIAL, PROPRIETARY AND/OR PRIVILEGED INFORMATION FOR THE SOLE USE OF THE INTENDED RECIPIENT(S). ANY REVIEW, USE, DISTRIBUTION, COPY OR DISCLOSURE BY OTHERS IS STRICTLY PROHIBITED. IF YOU ARE NOT THE INTENDED RECIPIENT (OR AUTHORIZED TO RECEIVE INFORMATION FOR THE RECIPIENT), PLEASE CONTACT THE SENDER AND DELETE ALL COPIES OF THIS MESSAGE.
THANK YOU
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://lists.osgeo.org/mailman/listinfo/qgis-user>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://lists.osgeo.org/mailman/listinfo/qgis-user>
Bernie Connors
Fredericton, NB
THANK YOU
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250409/243e478d/attachment.htm>
More information about the QGIS-User mailing list
