[Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
Abdou SENE / Geo - Tech - Dev
seneabdou460 at gmail.com
Fri Apr 11 08:40:22 PDT 2025
Hi Everyone,
Maybe it will be bizarrely appropriate but my question is : did you
connected to Internet when trying to load the basemap?
If not, remember doing it!
On Fri, Apr 11, 2025, 13:59 Hugh Kelley via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> OK thanks for clarifying, Krishna if you're still following, I think the
> key point remains that you're best bet is to update qgis.
> On Fri, Apr 11, 2025, 09:07 Andrea Giudiceandrea via QGIS-User <
>> Il 11/04/2025 14:34, Hugh Kelley ha scritto:
>> > Hi, maybe I'm not following the versions correctly. since they are
>> > using an older version, isn't the solution or first step simply
>> > upgrading qgis?
>> The issue reported at https://github.com/qgis/QGIS/issues/60807 didn't
>> occur using QGIS 3.34.15, so it cannot be the root cause of the issue
>> reported by Krishna Konduru. Moreover, the issue reported at
>> https://github.com/qgis/QGIS/issues/60807 only occurs when trying to
>> display EPSG3857 layers in a EPSG:5514 or EPSG:8353 project, while
>> Krishna Konduru reports that the issue occurs even trying to display
>> EPSG3857 layers in a EPSG3857 project.
>> Using QGIS 3.34.15 there was normally no issue displaying XYZ Tiles
>> layers, like the OpenStreetMap one.
>> Unfortunately, the info provided by Krishna Konduru are not detailed
>> enough to understand the root cause of the issue.
>> Regards.
>> Andrea
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250411/42214903/attachment.htm>
More information about the QGIS-User
