[Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
    Hugh Kelley
    hghklly at gmail.com
    Fri Apr 11 06:58:59 PDT 2025
OK thanks for clarifying, Krishna if you're still following, I think the
key point remains that you're best bet is to update qgis.
On Fri, Apr 11, 2025, 09:07 Andrea Giudiceandrea via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Il 11/04/2025 14:34, Hugh Kelley ha scritto:
> > Hi, maybe I'm not following the versions correctly.  since they are
> > using an older version, isn't the solution or first step simply
> > upgrading qgis?
> The issue reported at https://github.com/qgis/QGIS/issues/60807 didn't
> occur using QGIS 3.34.15, so it cannot be the root cause of the issue
> reported by Krishna Konduru. Moreover, the issue reported at
> https://github.com/qgis/QGIS/issues/60807 only occurs when trying to
> display EPSG3857 layers in a EPSG:5514 or EPSG:8353 project, while
> Krishna Konduru reports that the issue occurs even trying to display
> EPSG3857 layers in a EPSG3857 project.
> Using QGIS 3.34.15 there was normally no issue displaying XYZ Tiles
> layers, like the OpenStreetMap one.
> Unfortunately, the info provided by Krishna Konduru are not detailed
> enough to understand the root cause of the issue.
> Regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250411/14222bae/attachment.htm>
More information about the QGIS-User
