[Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Apr 11 06:07:09 PDT 2025
Il 11/04/2025 14:34, Hugh Kelley ha scritto:
> Hi, maybe I'm not following the versions correctly. since they are
> using an older version, isn't the solution or first step simply
> upgrading qgis?
The issue reported at https://github.com/qgis/QGIS/issues/60807 didn't
occur using QGIS 3.34.15, so it cannot be the root cause of the issue
reported by Krishna Konduru. Moreover, the issue reported at
https://github.com/qgis/QGIS/issues/60807 only occurs when trying to
display EPSG3857 layers in a EPSG:5514 or EPSG:8353 project, while
Krishna Konduru reports that the issue occurs even trying to display
EPSG3857 layers in a EPSG3857 project.
Using QGIS 3.34.15 there was normally no issue displaying XYZ Tiles
layers, like the OpenStreetMap one.
Unfortunately, the info provided by Krishna Konduru are not detailed
enough to understand the root cause of the issue.
Regards.
Andrea
More information about the QGIS-User
