[Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
Hugh Kelley hghklly at gmail.com
Fri Apr 11 05:34:44 PDT 2025
Hi, maybe I'm not following the versions correctly.  since they are using
an older version, isn't the solution or first step simply upgrading qgis?
I have been working around this or a similar issue myself and just waiting
for the fix in 6 days in 3.40.6.
On Fri, Apr 11, 2025, 08:24 Andrea Giudiceandrea via QGIS-User <
> > Thu Apr 10 02:42:38 PDT 2025
> > Hi, I believe this is a reported and fixed issue.
> > https://github.com/qgis/QGIS/issues/60807
> Hi Hugh,
> such issue occurs since QGIS LTR 3.40.4 and QGIS 3.42.0 (and will be
> fixed in QGIS LTR 3.40.6 and QGIS 3.42.2), while Krishna Konduru is
> reportedly using QGIS 3.34.15.
> Regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250411/d3c41505/attachment.htm>
More information about the QGIS-User mailing list
