[Qgis-user] Issues rendering after pasting into layers
Chiz Harward
chiz at urban-archaeology.co.uk
Mon Aug 18 22:20:14 PDT 2025
Thanks, Ill look into the symbology/attribute settings properly. It looked ok to me, but I'm a basic user! Ill try copying a layer that works ok and see if that works to paste into
Layer just doesn't display, did check the memory usage and seemed ok to me, have lots of empty RAM and memory
Thanks
Sent from Outlook for Android<https://aka.ms/AAb9ysg>
Sent: Tuesday, August 19, 2025 1:44:12 am
To: Chiz Harward <chiz at urban-archaeology.co.uk>
Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Issues rendering after pasting into layers
Hi Chiz,
Just regarding the polygons failing to show up...
Do you have a symbology on the table that assigns colours to polygons based on an attribute value with no default setting?
If the new polygons have such values which do not exist in the symbology setup, that could be why they don't render in that layer.
Is it just immediately after pasting the polygons, or also if you open the layer afresh, they still don't display?
I'm still on v3.34 (need to do something about that!) and have not expeienced the freezing issue.
I'm on Linux, but assume you are on Windows but you didn't say.
I'd look at the resources QGIS is using and see if it is just working very hard doing something, or is frozen & doing nothing.
It can appear similar to the user, but they are very different issues.
Cheers
Brent Wood
Principal Technician, Fisheries
NIWA
DDI: +64 (4) 3860529
On Mon, 18 Aug 2025 at 20:00, Chiz Harward via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
Morning,
Running 3.40.9-Bratislava, small project with a handful of layers.
When copying selected polygons into another polygon layer I am not getting the new polygons rendering in the view. The Feature Total of the layer goes up, and the nodes appear as red crosses, but there is no rendering of the polygons. The layer is at top of the layer bar and opacity bar is 100% so is not that
Also getting issues with the view freezing if I uncheck layers and the layer does not disappear from view, or the whole view goes blank, or cannot pan or zoom
Have restarted QGIS several times and restarted computer. Any suggestions appreciated for the rookie error I have made!
Best wishes
Chiz
Chiz Harward BA MCIfA he/him
Senior Archaeologist, Urban Archaeology
I work flexibly - so whilst it suits me to email now, I do not expect a response or action outside of your own working hours
New book on Minchinhampton Church out April 2025 https://www.hobnobpress.co.uk/books/p/your-church-newly-built-a-history-of-the-church-of-the-holy-trinity-minchinhampton-gloucestershire-by-chiz-harward
http://urban-archaeology.blogspot.com<http://urban-archaeology.blogspot.com/>
https://www.facebook.com/urb.arch/
http://gloscross-slabs.blogspot.co.uk/
Urban Archaeology
2 Slad View,
Gaineys Well,
Stroud,
Gloucestershire
GL5 1LQ
07881 486837
chiz at urban-archaeology.co.uk<mailto:chiz at urban-archaeology.co.uk>
Urban Archaeology is a trading name of Chiz Harward BA MCIfA
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Brent Wood
Principal Technician - GIS and Spatial Data Management
+64-4-386-0529
301 Evans Bay Parade Hataitai Wellington New Zealand
Earth Sciences New Zealand
[Earth Sciences New Zealand]<https://earthsciences.nz/>
The Institute of Geological and Nuclear Sciences Limited and the National Institute of Water and Atmospheric Research Limited joined to become the New Zealand Institute for Earth Science Limited. We are known as Earth Sciences New Zealand. For more information on the Earth Sciences transition click here<https://niwa.co.nz/about-niwa/science-sector-reforms>.
Notice: This email may contain information which is confidential and/or subject to copyright, and may not be used, published or redistributed without the prior written consent of Earth Sciences New Zealand. If you are not the intended recipient, please immediately notify the sender and delete the email and any attachments. Any opinion or views expressed in this email are those of the individual sender and may not represent those of Earth Sciences New Zealand.
For information about how we process data and monitor communications please see our privacy policy<https://niwa.co.nz/about-niwa/privacy-policy>.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250819/132e765b/attachment.htm>
More information about the QGIS-User
