[Qgis-user] Issues rendering after pasting into layers
oisin.kelly.wild at gmail.com oisin.kelly.wild at gmail.com
Mon Aug 18 22:43:24 PDT 2025
Did you get my message? If it's an SHP file try deleting it index a QIX file
⁣Oisin
Get BlueMail for Android ​
On 19 Aug 2025, 06:20, at 06:20, Chiz Harward via QGIS-User <qgis-user at lists.osgeo.org> wrote:
>Thanks, Ill look into the symbology/attribute settings properly. It
>looked ok to me, but I'm a basic user! Ill try copying a layer that
>works ok and see if that works to paste into
>Layer just doesn't display, did check the memory usage and seemed ok to
>me, have lots of empty RAM and memory
>Thanks
>Sent from Outlook for Android<https://aka.ms/AAb9ysg>
>________________________________
>From: Brent Wood <Brent.Wood at niwa.co.nz>
>Sent: Tuesday, August 19, 2025 1:44:12 am
>To: Chiz Harward <chiz at urban-archaeology.co.uk>
>Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
>Subject: Re: [Qgis-user] Issues rendering after pasting into layers
>Hi Chiz,
>Just regarding the polygons failing to show up...
>Do you have a symbology on the table that assigns colours to polygons
>based on an attribute value with no default setting?
>If the new polygons have such values which do not exist in the
>symbology setup, that could be why they don't render in that layer.
>Is it just immediately after pasting the polygons, or also if you open
>the layer afresh, they still don't display?
>I'm still on v3.34 (need to do something about that!) and have not
>expeienced the freezing issue.
>I'm on Linux, but assume you are on Windows but you didn't say.
>I'd look at the resources QGIS is using and see if it is just working
>very hard doing something, or is frozen & doing nothing.
>It can appear similar to the user, but they are very different issues.
>Cheers
>Brent Wood
>Principal Technician, Fisheries
>NIWA
>DDI:  +64 (4) 3860529
>On Mon, 18 Aug 2025 at 20:00, Chiz Harward via QGIS-User
><qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
>Morning,
>Running 3.40.9-Bratislava, small project with a handful of layers.
>When copying selected polygons into another polygon layer I am not
>getting the new polygons rendering in the view. The Feature Total of
>the layer goes up, and the nodes appear as red crosses, but there is no
>rendering of the polygons. The layer is at top of the layer bar and
>opacity bar is 100% so is not that
>Also getting issues with the view freezing if I uncheck layers and the
>layer does not disappear from view, or the whole view goes blank, or
>cannot pan or zoom
>Have restarted QGIS several times and restarted computer. Any
>suggestions appreciated for the rookie error I have made!
>Best wishes
>Chiz
>Chiz Harward BA MCIfA he/him
>Senior Archaeologist, Urban Archaeology
>I work flexibly - so whilst it suits me to email now, I do not expect a
>response or action outside of your own working hours
>New book on Minchinhampton Church out April 2025
>https://www.hobnobpress.co.uk/books/p/your-church-newly-built-a-history-of-the-church-of-the-holy-trinity-minchinhampton-gloucestershire-by-chiz-harward
>http://urban-archaeology.blogspot.com<http://urban-archaeology.blogspot.com/>
>https://www.facebook.com/urb.arch/
>http://gloscross-slabs.blogspot.co.uk/
>Urban Archaeology
>2 Slad View,
>Gaineys Well,
>Stroud,
>Gloucestershire
>GL5 1LQ
>07881 486837
>chiz at urban-archaeology.co.uk<mailto:chiz at urban-archaeology.co.uk>
>Urban Archaeology is a trading name of Chiz Harward BA MCIfA
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Brent Wood
>Principal Technician - GIS and Spatial Data Management
>+64-4-386-0529
>301 Evans Bay Parade Hataitai Wellington New Zealand
>Earth Sciences New Zealand
>[Earth Sciences New Zealand]<https://earthsciences.nz/>
>The Institute of Geological and Nuclear Sciences Limited and the
>National Institute of Water and Atmospheric Research Limited joined to
>become the New Zealand Institute for Earth Science Limited. We are
>known as Earth Sciences New Zealand. For more information on the Earth
>Sciences transition click
>here<https://niwa.co.nz/about-niwa/science-sector-reforms>.
>Notice: This email may contain information which is confidential and/or
>subject to copyright, and may not be used, published or redistributed
>without the prior written consent of Earth Sciences New Zealand. If you
>are not the intended recipient, please immediately notify the sender
>and delete the email and any attachments. Any opinion or views
>expressed in this email are those of the individual sender and may not
>represent those of Earth Sciences New Zealand.
>For information about how we process data and monitor communications
>please see our privacy
>policy<https://niwa.co.nz/about-niwa/privacy-policy>.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250819/84288d53/attachment-0001.htm>
More information about the QGIS-User mailing list
