[Qgis-user] Filtering NULL values from WFS
Reetz, Michael (NLPVW)
Michael.Reetz at nlpvw.niedersachsen.de
Tue Aug 26 07:46:31 PDT 2025
Hello group,
I've added a WFS-layer to a project try to define filters on different attributes. It seems not to be possible to filter for NULL values.
Example:
* 1932 records in total
* 376 records with a value in a date attribute
* 20 records with 2005-12-31 as value
If I set the filter to "end_date" = '2005-12-31' the result is 20 records.
If I set the filter to "end_date" != '2005-12-31' the result is 356 records. So only records that have an end date are recognized. Record with NULL as end date are ignored.
Filtering in the attribute table with "is_empty_or_null" works but only for selection.
Is this "normal" behaviour with WFS layers or is there a way to define a filter string that work for all records?
QGIS-Version is 3.40.4-Bratislava
Best regards
Michael
Michael Reetz
Datenbanken und Anwendungsentwicklung
Nationalpark-Verwaltung Niedersächsisches Wattenmeer
Virchowstr. 1 | 26382 Wilhelmshaven
Tel.: +49 (0) 4421 911 291
e-mail: michael.reetz at nlpvw.niedersachsen.de<mailto:michael.reetz at nlpv-wattenmeer.niedersachsen.de>
Web: https://www.<https://www./>nationalpark-wattenmeer.de
[cid:image003.png at 01DC16A8.F8DA11B0]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250826/61816904/attachment.htm>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250826/61816904/attachment.png>
More information about the QGIS-User
