[Qgis-user] Filtering NULL values from WFS
pathmapper pathmapper at posteo.de
Tue Aug 26 08:43:57 PDT 2025
you could try a filter with
  "end_date" is NULL
or
  "end_date" is not NULL
And it should be possible to combine filters, e.g. with AND:
"end_date" != '2005-12-31' AND "end_date" is NULL
Cheers,
Björn
On 26.08.2025 16:46, Reetz, Michael (NLPVW) via QGIS-User wrote:
> Hello group,
> I've added a WFS-layer to a project try to define filters on different
> attributes. It seems not to be possible to filter for NULL values.
> Example:
>  	* 1932 records in total
> 	* 376 records with a value in a date attribute
> 	* 20 records with 2005-12-31 as value
> If I set the filter to "end_date" = '2005-12-31' the result is 20
> records.
> If I set the filter to "end_date" != '2005-12-31' the result is 356
> records. So only records that have an end date are recognized. Record
> with NULL as end date are ignored.
> Filtering in the attribute table with "is_empty_or_null" works but
> only for selection.
> Is this "normal" behaviour with WFS layers or is there a way to define
> a filter string that work for all records?
> QGIS-Version is 3.40.4-Bratislava
> Best regards
> Michael
> Michael Reetz
> Datenbanken und Anwendungsentwicklung
>  Nationalpark-Verwaltung Niedersächsisches Wattenmeer
>  Virchowstr. 1 | 26382 Wilhelmshaven
>  Tel.: +49 (0) 4421 911 291
>  e-mail: michael.reetz at nlpvw.niedersachsen.de
>  Web: https://www. [1]nationalpark-wattenmeer.de
> Links:
> [1] https://www./
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
