[Qgis-user] lettering
Jacqueline Aydt
j.aydt at kartenkonstrukt.ch
Wed Dec 10 23:12:14 PST 2025
Hi Marc,
Did you import the dxf via import-tool (onboard or „another dxf
importer“-plugin) or drag and drop?
An import tool usually gives you a better import result of your
layers (filters and groups them) and, as far as I have encountered it,
also places labels the way they would be in CAD by accessing the
rotation labels that might be imbedded in the dxf file.
Maybe that helps?
Liebe Grüße,
Jackie Aydt
Am 10.12.2025, 09:51, Marc Weber via QGIS-User
<qgis-user at lists.osgeo.org> schrieb:
> Hi,
> I’m facing the following issue: I imported the sewer network from
> a DXF file, along with the corresponding labels. However, the
> channel geometries and the labels are stored in separate layers and
> are not linked to each other. Although the attribute table of the
> label layer contains a “Rotation” field, QGIS still displays the
> text horizontally by default.
> In the layer properties, under “Placement,” you can specify a
> rotation angle—I've tried that, but the label orientations are
> still not correct. I suspect that the reference point of the labels
> was set arbitrarily during the import, which prevents the rotation
> from being applied properly.
> My goal is to reproduce the same label layout as in the original DXF
> file.
> Does anyone have an idea how to solve this problem?
> Mit freundlichen Grüßen
> Marc Weber
> HSI CONSULT GMBH
> Bahnhofsplatz 8
> D-54292 Trier
> Telefon
> +49 (0) 651 / 93836 - 18
> marc.weber at hsi-trier.de
> www.hsi-trier.de [http://www.hsi-trier.de/]
> [https://www.hsi-trier.de/]
> HSI Consult GmbH
> Vertretungsberechtigter Geschäftsführer: Peter Mauer, Max Senger |
> Handelsregister HRB 43234 | Amtsgericht Wittlich |
> USt.-ID: DE 301433955
> DATENSCHUTZ | Über den Umgang mit personenbezogenen Daten finden
> sie unsere Hinweise online abrufbar über folgenden Link
> [https://www.hsi-trier.de/j/privacy].
> BITTE BEACHTEN SIE | Diese Nachricht ist nur für die Person(en)
> bestimmt, an die sie adressiert ist. Der Inhalt dieser Nachricht
> und eventueller Anhänge ist vertraulich. Jede Durchsicht,
> Übertragung, Verbreitung oder anderweitige Nutzung, oder das
> Ergreifen von Maßnahmen im Vertrauen auf diese Nachricht durch
> Personen, die nicht beabsichtigte Adressaten sind, ist nicht
> gestattet und kann widerrechtlich sein. Wenn Sie nicht der
> beabsichtigte Empfänger sind, dann löschen Sie diese E-Mail bitte
> sofort mit ihren Anhängen und informieren den Absender.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Jacqueline Aydt - Kartenkonstrukt
www.kartenkonstrukt.ch [http://www.kartenkonstrukt.ch]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251211/892a13e0/attachment.htm>
More information about the QGIS-User
