[Qgis-user] lettering
Nigel Berjak - General nigel at s3.co.za
Wed Dec 10 05:53:49 PST 2025
Hi Marc
Usually the rotation etc. is done either to true north or at 90° to
this, so I would test by adding 90 to the rotation expression in the
labels to see whether this works.
Perhaps you could store everything inside a geopackage rather, similar
to a CAD file, although yes, they are not all linked. You could then do
table join if you wanted to, but probably unnecessary. You can emulate
the CAD colours by having a CSV table of RGB colours, which relate to
the CAD colour names and which then you can link to the attributes and
use the RGB in your colour expression and in the same way as well as
line type. You can also emulate the line thickness by using the
attribute in the line layer.
Hopefully this helps.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2025-12-10 10:51, Marc Weber via QGIS-User wrote:
> Hi,
> I'm facing the following issue: I imported the sewer network from a DXF
> file, along with the corresponding labels. However, the channel
> geometries and the labels are stored in separate layers and are not
> linked to each other. Although the attribute table of the label layer
> contains a "Rotation" field, QGIS still displays the text horizontally
> by default.
> In the layer properties, under "Placement," you can specify a rotation
> angle--I've tried that, but the label orientations are still not
> correct. I suspect that the reference point of the labels was set
> arbitrarily during the import, which prevents the rotation from being
> applied properly.
> My goal is to reproduce the same label layout as in the original DXF
> file.
> Does anyone have an idea how to solve this problem?
> Mit freundlichen Grüßen
> Marc Weber
> HSI Consult GmbH
> Bahnhofsplatz 8
> D-54292 Trier
> Telefon
> +49 (0) 651 / 93836 - 18
> marc.weber at hsi-trier.de
> www.hsi-trier.de [1]
> [2]
> HSI Consult GmbH
> Vertretungsberechtigter Geschäftsführer: Peter Mauer, Max Senger |
> Handelsregister HRB 43234 | Amtsgericht Wittlich |
> USt.-ID: DE 301433955
> Datenschutz | Über den Umgang mit personenbezogenen Daten finden sie
> unsere Hinweise online abrufbar über folgenden Link [3].
> Bitte beachten Sie | Diese Nachricht ist nur für die Person(en)
> bestimmt, an die sie adressiert ist. Der Inhalt dieser Nachricht
> und eventueller Anhänge ist vertraulich. Jede Durchsicht, Übertragung,
> Verbreitung oder anderweitige Nutzung, oder das
> Ergreifen von Maßnahmen im Vertrauen auf diese Nachricht durch
> Personen, die nicht beabsichtigte Adressaten sind, ist nicht
> gestattet und kann widerrechtlich sein. Wenn Sie nicht der
> beabsichtigte Empfänger sind, dann löschen Sie diese E-Mail bitte
> sofort mit ihren Anhängen und informieren den Absender.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Links:
[1] http://www.hsi-trier.de/
[2] https://www.hsi-trier.de/
[3] https://www.hsi-trier.de/j/privacy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251210/a3254680/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251210/a3254680/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251210/a3254680/attachment-0001.png>
More information about the QGIS-User mailing list
