[Qgis-user] Assistance with Calculating Polygon Area in Hectares (EPSG:25832)
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Dec 18 00:55:03 PST 2025
> Phil Wyatt phil at wyatt-family.com
> Wed Dec 17 23:39:25 PST 2025
> Make sure the field is Decimal with a precision of 3
Hi Phil,
the result of the expression
round( $area / 10000, 2) || ' ha'
is a string, thus the field type set in the Field Calculator should
actually be Text, not Decimal, in order to correctly store the result of
such expression.
> Christoffer Toft Hviid Jensen cth at patriotisk.dk
> Wed Dec 17 23:22:30 PST 2025> I use this expression round( $area /
10000, 2) || ' ha' in the calculator box through the attributtable.
Hi Christoffer, the function round() obviously returns 0 if the first
argument is equal or less than 0.004 and the second argument is set to 2.
So the expression will return '0 ha' if $area / 10000 is equal or less
than 0.004 (ie $area is equal or less 40).
Are you sure that $area / 10000 is greater than 0.004 (ie $area is
grater than 40) for the given features?
Moreover, the unit of measure of the value returned by the function
$area (which calculates the Ellipsoidal area of a geometry) is the unit
of measure set in Project Properties -> General -> Measurements -> Units
for area measurements.
Since you are using the formula $area / 10000 in your expression, then
the unit of measure of the value returned by the function $area should
be square meters in order for the formula $area / 10000 to return a
value in hectares.
Are you sure such settings is set to 'Square Meters'?
Regards.
Andrea
More information about the QGIS-User
