[Qgis-user] reduce number of open files in pyqgis script
Martin Landa
landa.martin at gmail.com
Fri Dec 26 03:24:29 PST 2025
Dear all,
I have a standalone pyqgis script which processes multiple layers stored in
a single GPKG. The first part of the script loops over layers, performs
clipping by extent and stores the result in a memory layer. The problem
which I am facing is the increasing number of open files which easily reach
the OS limit. The sample script:
import sys
import psutil, os
import gc
from qgis.core import QgsProviderRegistry, QgsVectorLayer, QgsRectangle,
QgsFeatureRequest, QgsWkbTypes, QgsFeature, QgsGeometry
def open_files_count():
return len(process.open_files())
def clip_layer(layer: QgsVectorLayer, extent: QgsRectangle, layer_name:
str) -> QgsVectorLayer:
extent_geom = QgsGeometry.fromRect(extent)
clipped_layer = QgsVectorLayer(
f"{QgsWkbTypes.displayString(layer.wkbType())}?crs={layer.crs().authid()}",
layer_name,
"memory"
clipped_layer.dataProvider().addAttributes(layer.fields())
clipped_layer.updateFields()
for feature in
layer.getFeatures(QgsFeatureRequest().setFilterRect(extent)):
geom = feature.geometry()
if geom.intersects(extent_geom):
clipped_feature = QgsFeature()
clipped_feature.setGeometry(geom.intersection(extent_geom))
clipped_feature.setAttributes(feature.attributes())
clipped_layer.dataProvider().addFeature(clipped_feature)
clipped_feature = None
clipped_layer.commitChanges()
return clipped_layer
process = psutil.Process(os.getpid())
gpkg_path = "/home/martin/geodata/ZABAGED20251006.gpkg"
layers = QgsProviderRegistry.instance().querySublayers(gpkg_path)
extent = QgsRectangle(-653547, -1065864, -653225, -1065600)
clipped_layers = []
for sublayer in layers:
name = sublayer.name()
layer = QgsVectorLayer(sublayer.uri(), 'ogr')
clipped_layer = clip_layer(layer, extent, layer.name())
del layer
print(name, open_files_count())
if clipped_layer.featureCount() == 0:
del clipped_layer
continue
clipped_layers.append(clipped_layer)
When launching the script number of open file is increasing regardless any
attempts to release data sources (del layer, layer = None, gc.collect(),
ZeleznicniStaniceZastavka 3
ZeleznicniPrejezd_b 4
ZdrojPodzemnichVod 5
BazinaMocal 172
ArealZeleznicniStaniceZastavky 173
ArealUceloveZastavby 174
Please how to release data sources correctly to avoid increasing the number
of open files?
Thanks in advance, Martin
Martin Landa
https://geomatics.fsv.cvut.cz/en/employees/martin-landa/
https://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251226/c034289f/attachment.htm>
More information about the QGIS-User
