[Qgis-user] Arctic data distortion when crossing the 180° meridian (EPSG:3996 vs EPSG:3857)
김용운 빙하지권연구본부 kyu at kopri.re.kr
Tue Dec 23 19:48:13 PST 2025
Hello,
I am working with Arctic Ocean datasets in QGIS and would like to ask for advice regarding CRS handling and geometries crossing the 180° meridian.
For Arctic data, I normally use EPSG:3996 (WGS 84 / Arctic Polar Stereographic) as the project CRS. In QGIS Desktop, this works well and produces the expected visualization for tracks and stations (Figure 1).
However, when I try to use these datasets in a web mapping context, I am forced to switch the project CRS to EPSG:3857. With this change, datasets that cross the 180° meridian (anti-meridian) show problematic behavior:
- line features are split and displayed at both sides of the map,
- and in some cases the geometries appear distorted or disconnected (Figures 3 and 5).
The original geometry itself is correct (Figure 4), so the issue seems to be related to CRS transformation and rendering rather than data corruption.
I tested several CRS combinations, and the following produced the closest alignment:
- Project CRS = EPSG:3857
- Layer CRS = EPSG:3996
Nevertheless, the anti-meridian splitting issue remains unresolved. I also tried suggestions found in documentation and online discussions (e.g. reprojection, geometry fixes, alternative basemaps), but none solved the problem fundamentally.
Since many Arctic datasets naturally cross the 180° meridian, I would greatly appreciate advice on:
- best practices for handling Arctic/polar data in QGIS,
- recommended CRS strategies when working near the anti-meridian,
- or preprocessing steps that can prevent line splitting and visual discontinuities.
Thank you very much for your time and any suggestions.
Best regards,
[https://bigfile.kopri.re.kr/readreceipt2.ashx?id=MTQwYzAxNjQtYmI4OS00NWYxLWE5MzQtNTc1OTAyMDdmZDcx]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251224/d41d3ed4/attachment-0001.htm>
Type: image/png
Desc: 01_Expected_QGIS_EPSG3996_Project_EPSG4326_Layers.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251224/d41d3ed4/attachment-0005.png>
Type: image/png
Desc: 02_QWC2_Error_EPSG3996_Not_Defined.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251224/d41d3ed4/attachment-0006.png>
Type: image/png
Desc: 03_QWC2_Distortion_Project3857_Layers3996.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251224/d41d3ed4/attachment-0007.png>
Type: image/png
Desc: 04_Raw_Track_Geometry_Normal_View.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251224/d41d3ed4/attachment-0008.png>
Type: image/png
Desc: 05_Track_Split_Across_Antimeridian_180deg.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251224/d41d3ed4/attachment-0009.png>
More information about the QGIS-User mailing list
