[Qgis-user] QGIS GNSS NMEA Transformation Problem WGS84 to MGI Austria
Peter Hartl
office at hartl-consulting.at
Fri Feb 7 05:51:54 PST 2025
Hallo Greg,
thanks for Information, will check NMEA RTK data in detail first.
Greetings
Peter Hartl
Von meinem iPhone gesendet
> Am 07.02.2025 um 13:22 schrieb Greg Troxel via QGIS-User <qgis-user at lists.osgeo.org>:
> Peter Hartl via QGIS-User <qgis-user at lists.osgeo.org> writes:
>> GNSS NMEA interpreted as WGS84 in QGIS can do transformation with
>> gridshift from ETRS89 to MGI, that is alredy working very good.
> What do you mean by "GNSS NMEA interpreted as WGS84"? What reference
> frame is your GNSS data actually in? It could be
> WGS84(G2159) if you are using a non-differential solution
> ITRF? if you are using SBAS
> ETRF? if you are using some RTK network
> something else, if your receiver is combining 4 constellations, each
> of which have their own frames, and doing something that they don't
> document (hint: I have never seen any receiver document this.)
> You should be aware that WGS84 is an ensemble, which means that when you
> say data is in WGS84 that it is in one of several datums, and you don't
> know which one.
> The inherent accuracy limitation of the ensemble is about 2m. So
> therefore a shift of 30 cm is not wrong.
> Probably, it would be good to figure out how to not use WGS84,
> especially if you are tryig to work at sub-meter accuracy. I have
> done this by gathering data in NAD83(2011) epoch 2010.0, which is more
> plate fixed, more or less analagous to ETRS89, using RTK with a
> reference network operating in NAD83.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
