[Qgis-user] QGIS GNSS NMEA Transformation Problem WGS84 to MGI Austria
Peter Hartl
office at hartl-consulting.at
Sat Feb 8 09:54:56 PST 2025
Thanks Greg,
QGIS interprets NMEA data as WGS84 geographic data which is correct!
I could not find to say to QGIS that it should use ETRS89 datum!
We are using *QField*, here Transformation in X, Y from GNNS into our
MGI with gridshift is working correkt (Vertical girdshift works too very
goo in cm accuracy)!
The *same QGIS projekt behind with QGIS* shows data in map correct (set
to 25832) but in saving to 31254 it gets shift, without possibiltity for
changing that for me.
For me it looks like a issue in QGIS!
Herzliche Grüße
Hartl Consulting e. U.
DI Peter Hartl MAS(GIS)
Gröben 11
A-6134 Vomp
Tel.: +43 660 17 42 228
www.hartl-consulting.at
Am 07.02.2025 um 14:51 schrieb Peter Hartl via QGIS-User:
> Hallo Greg,
> thanks for Information, will check NMEA RTK data in detail first.
> Greetings
> Peter Hartl
> Von meinem iPhone gesendet
>> Am 07.02.2025 um 13:22 schrieb Greg Troxel via QGIS-User<qgis-user at lists.osgeo.org>:
>> Peter Hartl via QGIS-User<qgis-user at lists.osgeo.org> writes:
>>> GNSS NMEA interpreted as WGS84 in QGIS can do transformation with
>>> gridshift from ETRS89 to MGI, that is alredy working very good.
>> What do you mean by "GNSS NMEA interpreted as WGS84"? What reference
>> frame is your GNSS data actually in? It could be
>> WGS84(G2159) if you are using a non-differential solution
>> ITRF? if you are using SBAS
>> ETRF? if you are using some RTK network
>> something else, if your receiver is combining 4 constellations, each
>> of which have their own frames, and doing something that they don't
>> document (hint: I have never seen any receiver document this.)
>> You should be aware that WGS84 is an ensemble, which means that when you
>> say data is in WGS84 that it is in one of several datums, and you don't
>> know which one.
>> The inherent accuracy limitation of the ensemble is about 2m. So
>> therefore a shift of 30 cm is not wrong.
>> Probably, it would be good to figure out how to not use WGS84,
>> especially if you are tryig to work at sub-meter accuracy. I have
>> done this by gathering data in NAD83(2011) epoch 2010.0, which is more
>> plate fixed, more or less analagous to ETRS89, using RTK with a
>> reference network operating in NAD83.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250208/42efa420/attachment.htm>
More information about the QGIS-User
