[Qgis-user] QGIS GNSS NMEA Transformation Problem WGS84 to MGI Austria
Greg Troxel
gdt at lexort.com
Sat Feb 8 10:35:38 PST 2025
Peter Hartl via QGIS-User <qgis-user at lists.osgeo.org> writes:
> QGIS interprets NMEA data as WGS84 geographic data which is correct!
No, it is not correct. It is only correct it the receiver is operating
in WGS84. That is true *only* for non-differential solutions. That
means not with SBAS, not with RTK.
And, it's also not correct because WGS84 is an ensemble.
> I could not find to say to QGIS that it should use ETRS89 datum!
I think that's a missing feature. The feature is missing in QField too:
https://github.com/opengisch/QField/issues/2855
There's another problem, which is that proj, when asked to transform
from WGS84 to NAD83(2011) 2010.0, uses a null transform. That
technically makes sense because WGS84(TRANSIT) is roughly equal to
NAD83(1986). But it doesn't actually make sense.
> We are using *QField*, here Transformation in X, Y from GNNS into our
> MGI with gridshift is working correkt (Vertical girdshift works too
> very goo in cm accuracy)!
But what is the actual datum your NMEA is in? What kind of GNSS are you
using?
> The *same QGIS projekt behind with QGIS* shows data in map correct
> (set to 25832) but in saving to 31254 it gets shift, without
> possibiltity for changing that for me.
> For me it looks like a issue in QGIS!
Maybe but you have not answered my questions about what is really going
on, and you may be operating in a mode where multiple bugs sometimes
cancel and sometimes do not.
More information about the QGIS-User
