[Qgis-user] QuickOSM Failed to install
Güttel, Christoph Christoph.Guettel at anhalt-bitterfeld.de
Thu Feb 27 02:51:25 PST 2025
use https://qgis.org/downloads/QGIS-OSGeo4W-3.40.4-1.msi
without Qt6 and the plugin QuickOSM run. The Long Term Version for Windows (3.40) with Qt6 is experimental!
Best Regards.
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Yohanees Hutagalung via QGIS-User
Gesendet: Donnerstag, 27. Februar 2025 09:34
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] QuickOSM Failed to install
Dear Team,
I am newbie user of QGIS.
I tried to install plugins QuickOSM either direct from QGIS or install from ZIP 2.3.2, but i got error:
The plugin is not compatible with this version of QGIS. It's designed for QGIS versions: Plugin does not support Qt6 versions of QGIS.
What should I do?
Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250227/a4c80b30/attachment.htm>
More information about the QGIS-User mailing list
