[Qgis-user] Open ESRI Geodatabase file in QGIS
Andrea Giudiceandrea
andreaerdna at libero.it
Mon Jan 13 01:35:51 PST 2025
> Mangla Katyayani mangla.katyayani at gramener.com > Sun Jan 12 20:38:25 PST 2025 > I am facing this problem while
opening a geodatabase file in QGIS. I have > followed the following
steps: > Add layer> Add vector layer>Directory> Type: openfilegdb Hi
Mangla, looking at the Name, Path and Source strings displayed in the
provided screenshot, it looks like you have added the ESRI File
Geodatabase layer using the "Add layer -> Add vector layer -> File"
dialog window instead of "Add layer -> Add vector layer -> Directory ->
Type: openfilegdb" Does a "Select Items to Add" dialog (like in the
attached screenshot) window pops up after adding the ESRI File
Geodatabase directory via "Add layer -> Add vector layer -> Directory ->
Type: openfilegdb"?Are there any error messages displayed in the Log
Messages panel? Is the ESRI File Geodatabase supposed to contain vector
layers or raster layers? Is the ESRI File Geodatabase supposed to
contain only 1 layer or multiple layers? What is the output of the
"Vector Information" processing algorithm run selecting any *.gdbtable
in the *.gdb folder as "Input layer" and checking the "Enable listing of
all layers in the dataset" checkbox? It would be useful if you provided
the QGIS full version info (available in the menu Help -> About) and if
you provided a link to download a zipped archive of the ESRI File
Geodatabase directory. Best regards. Andrea Giudiceandrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250113/c0f19d8d/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250113/c0f19d8d/attachment-0001.png>
More information about the QGIS-User
