[Qgis-user] symbology QGIS
Andrea Giudiceandrea andreaerdna at libero.it
Tue Jan 21 10:31:50 PST 2025
Hi Julia,
without more detailed info about your data (and the QGIS version used)
and about how did you set the symbolization options, it would be
difficult to understand what's exactly the issue and how to help you to
fix it.
I would suggest you to read the documentation available at [1] and [2].
Regards.
Andrea
[1]
https://docs.qgis.org/3.34/en/docs/user_manual/working_with_vector/vector_properties.html#categorized-renderer
[2]
https://docs.qgis.org/3.34/en/docs/training_manual/vector_classification/classification.html
> Julia | Bureau Endemica Julia at endemica.nl
> Tue Jan 21 04:42:12 PST 2025
> When I use categorized symbology on my polygon shapefile in QGIS, a part of the features is assigned the category "other values". Then, the features in this category receive that same color. In my case, however, I also want the features that end up under "other values" to be categorized with their own color. I don't understand how to change that and I also don't understand why specifically these features are categorized as other values. Is there anyone who can help me with this?
More information about the QGIS-User mailing list
