[Qgis-user] Geospatial PDF Not Measuring Distance Properly
Andrea Giudiceandrea andreaerdna at libero.it
Thu Jan 23 11:12:39 PST 2025
Il 23/01/2025 19:49, Andrea Giudiceandrea ha scritto:
> As explained in the issue report's comments, the issue is due to the
> fact that the print layout contains  2 totally overlapping Map items
> ("Map 1" and "Map 2") with the same size and position in the layout's
> page but having different scale and extent.
In particular, you need to remove the "Map 1" Map item (which is
actually empty and hidden under the "Map 2" map item) selecting it in
the "Items" panel and pressing the Del or the Canc button on your
keyboard or right-clicking with the mouse and selecting the "Delete
Item" action.
Then you need to select the "Scalebar" item and link it to the "Map 2"
map item (Item Properties -> Main Properties -> Map -> "Map 2") and then
select the "North Arrow" picture item and link it to the "Map 2" map
(Item Properties -> Image Rotation -> Sync with map -> "Map 2") .
Regards.
Andrea
More information about the QGIS-User mailing list
