[Qgis-user] ideas/examples of atlas/report with multiple pictures for each object?
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Fri Jan 24 02:13:01 PST 2025
I would use an Atlas - better then report, since reports haven't been
further developed - and then use 3 pages. You can add pages clicking in
the menu: Layout -> add pages. Then you go to page properties for the
second page. there is a checkbox "exclude page from export" where you
can use data defined override to check if the first photo on this page -
photo number 3 for example does exists. You can use the function:
not file_exists(@project_folder || '/photos/' || "object_id" || '/basename_' || "picture_id" || '.jpg').
If the photo does not exists, the page will not be exported, do the same
with the third page...
Best regards
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unseren Projekten
https://wheregroup.com/blog/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 24.01.2025 um 08:50 schrieb Voisard François via QGIS-User:
> Hi all,
> I am looking for ideas/examples how to create a report (or an atlas) where for each object (e.g. public gardens) we have a variable number of photos (let's say 1 up to 9) that we would like to display.
> The photos are named and stored so that we can fetch them by an expression like this:
> The issue I run into is that I would need a loop to get all the photos in the object_id folder and that depending on the number I'd probably have, one up to three pages with photos depending on the layout.
> A very simple example of a layout would be like this :https://sitn.ne.ch/web/diffusion/tmp/qgis_atlas_example.png
> Any suggestions how to approach it? Report or atlas?
> With an HTML element block maybe?
> Any existing examples?
> Many thanks for your help and best regards,
> François Voisard
> Ingénieur en géomatique
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/7cfdc401/attachment-0001.htm>
Name: 2025-01-24 11_01_30-Freiburg.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/7cfdc401/attachment-0001.png>
More information about the QGIS-User
