[Qgis-user] Georeferencing Problem in QGIS-Version 3.34.12-Prizren
    Belal Elsharkawy
    Belal.Elsharkawy at mup-group.com
    Fri Jan 24 07:30:14 PST 2025
Hello everyone,
if anyone has an idea or can help, I have a problem with georeferencing any 2D plan since a long time and have tried almost everything possible.
After importing the georeferencing wanted plan in the Georeferencing window in QGIS and choosing 3 points and their representatives in the main window plan, then going to the settings in the Georeferencing window to check the coordinate system and make sure that it’s the same as the one used in the main QGIS window as well as the Location where it will be saved.
I always get a very big differences in the dx (Pixel) as well as the dy (Pixel) which they should be zero or near to zero  (see the screenshot attached) and it doesn’t work.
While other colleagues doing literally the same as I do, and it works for them.
P.s. I tried using other different versions, unfortunately I encounter the same problem.
Best Regards,
M.Sc.
Belal Elsharkawy
Mull und Partner Ingenieurgesellschaft mbH
[cid:image001.png at 01DB6E7C.C33A4EA0]
Widdersdorfer Straße 190
50825
Köln
Deutschland
[cid:image002.png at 01DB6E7C.C33A4EA0]
 Belal.Elsharkawy at mup-group.com<mailto:Belal.Elsharkawy at mup-group.com>
[cid:image003.png at 01DB6E7C.C33A4EA0]
 +49 2211 7091730<tel:+49%202211%207091730>
[cid:image004.png at 01DB6E7C.C33A4EA0]
www.mullundpartner.de<https://eu.content.exclaimer.net?url=https%3A%2F%2Fmullundpartner.de%2F&tenantid=EOkRHthdEe2fdAANOry0EQ&templateid=2da4d76ccd2bee11b8f0000d3abcb411&excomponentid=YVl4MvQ680RUCfwiZdY_4U7AaFnxxk5NIbrk5qeu5iA&excomponenttype=Link&signature=ZauG-F6jwilViO1KuwaBwLgXMnUOcdHG95Zqfxu9QM49nCXJn_kMDfbN6MuMtlVa_pbwWg6L-4KfjJSn6P1UZ7RcvAPx2K7_Pkgl1OiFM3hF8PPWcVyTo29FbCpa6lNoscTTwMTK7IIxjLJf3qG4HL9dqACm4496ZOkJu3Gp_0XgpDOuUEJBBKSUu9gzr1oj3FcSVzZhR8e8qpZZ0Rzb6Ft55MiShl52DjeNorwVclI81R7w1_JcUbKbhZl1REy4cB6wRMjvQ3z5wVtfUUi8uXJ_gJbQbynvURLD0HNZvbIemsI2Imbg0W5iRZkFKfA_J0fh3XltT2fgRbFDeHWHXQ&v=1>
[cid:image005.png at 01DB6E7C.C33A4EA0]
Engineering for a Better Tomorrow
Mull und Partner Ingenieurgesellschaft mbH Köln
Geschäftsführung: Dr. Jürgen Margane, Dipl.-Geol. Christoph Richter, Dipl.-Geol. Axel Fahrenwaldt, Dipl.-Geol. Matthias von Herz
Sitz der Gesellschaft: Köln, Deutschland
Amtsgericht Köln HRB 51628
Umsatzsteuer-Identifikationsnummer gemäß § 27 a Umsatzsteuergesetz: DE 120 692 212
Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This e-mail contains confidential and/or legally protected information. If you are not the correct addressee or have received this e-mail in error, please inform the sender immediately and destroy this e-mail. Unauthorised copying or distribution of this e-mail is not permitted.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0006.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0007.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0008.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0009.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0010.png>
Name: Georeferencing Problem.png
Type: image/png
Desc: Georeferencing Problem.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250124/cc842c54/attachment-0011.png>
More information about the QGIS-User
