[Qgis-user] Qgis server postgis layers not valid (but desktop works on same machine)
Jorge Gustavo Rocha jgr at geomaster.pt
Mon Jul 7 14:12:26 PDT 2025
Hi Amedeo,
Is the www-data user able to read the pg service file? If you didn't
change the permissions, /home/ubuntu/.pg_service.conf is only readable
by ubuntu user.
Can you check the qgis server logs to see what is going on?
Best regards,
Jorge
Às 21:05 de 07/07/25, Amedeo Fadini via QGIS-User escreveu:
> Errata corrige, the demo project works, the sqlite file was with wrong
> permission.
> Still doesn't load postgis layer
> Amedeo
> Il giorno lun 7 lug 2025 alle ore 21:54 Amedeo Fadini
> <amefad at gmail.com> ha scritto:
>     Hi everybody,
>     I'm upgrading a project based on QGIS server and moved all stuff
>     to new server with Ubuntu 24, QGIS 3.40 LTR postgresql 16.
>     Webserver is nginx, QGIS server is configured on spawn-fcgi with
>     single socket follwing the qgis manual
>     https://docs.qgis.org/3.40/en/docs/server_manual/getting_started.html#spawn-fcgi
>     The project use two layers from postgis, the connection is
>     configured with pg service
>     Connecting on ssh with x.forwarding the project loads without any
>     error and works fine
>     Calling the qgis server getcapabilities or get projectsettings it
>     raise the error
>     <ServerException>Layer(s) not valid</ServerException>
>     Setting QGIS_SERVER_IGNORE_BAD_LAYERS=true getcapabilities works
>     but postgis layer are not published or not showed in Getmap request.
>     Any clue? Where can  I find more detailed erro log?
>     even the demo project world.qgs gives balnk image in getmap
>     request. Am I misisng a local Xserver or gui configuration?
>     Below is my nginx conf and systemd/system/qgis-server.service
>     Thank you
>     Amedeo Fadini
>     server {
>         listen 80;
>         server_name <my server name>;
>         location /qgis/ {
>             include fastcgi_params;
>             fastcgi_param SCRIPT_FILENAME
>     /usr/lib/cgi-bin/qgis_mapserv.fcgi;
>             #fastcgi_param  QGIS_DEBUG              1;
>             fastcgi_param QGIS_SERVER_LOG_STDERR 1;
>             #fastcgi_param QGIS_SERVER_LOG_LEVEL 0;
>             fastcgi_param QGIS_SERVER_LOG_LEVEL 2;
>             #fastcgi_param  PGSERVICEFILE /home/ubuntu/.pg_service.conf;
>             #fastcgi_param  QGIS_PROJECT_FILE
>     /home/ubuntu/fiduciali_qgis/fiduciali.qgs;
>             fastcgi_pass unix:/var/run/qgisserver.socket;
>     [Unit]
>     Description=QGIS server
>     After=network.target
>     [Service]
>     ;; set env var as needed
>     ;Environment="LANG=en_EN.UTF-8"
>     ;Environment="QGIS_SERVER_PARALLEL_RENDERING=1"
>     ;Environment="QGIS_SERVER_MAX_THREADS=12"
>     Environment="QGIS_SERVER_LOG_LEVEL=0"
>     Environment="QGIS_SERVER_LOG_STDERR=1"
>     Environment="PGSERVICEFILE=/home/ubuntu/.pg_service.conf"
>     ;Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/world.qgs"
>     Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/fiduciali.qgs"
>     Environment="QGIS_SERVER_IGNORE_BAD_LAYERS=true"
>     ;; or use a file:
>     ;EnvironmentFile=/etc/qgis-server-env
>     ExecStart=spawn-fcgi -s /var/run/qgisserver.socket -U www-data -G
>     www-data -n /usr/lib/cgi-bin>
>     [Install]
>     WantedBy=multi-user.target
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
*Geomaster, LDA *
*VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC *
Rua Afonso Palmeira, 31, 7 D
4715-278 Braga
VAT/NIF 510 906 109
Phone  +351 253 257 173
Site geomaster.pt <http://geomaster.pt>
GPS 41.54627, -8.40432
Logo
Jorge Gustavo Rocha
CTO
Mobile   +351 910 333 888
Email jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250707/166e4525/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250707/166e4525/attachment-0001.png>
More information about the QGIS-User mailing list
