[Qgis-user] Qgis server postgis layers not valid (but desktop works on same machine)
Amedeo Fadini
amefad at gmail.com
Tue Jul 8 01:43:19 PDT 2025
Hi jorge,
thank you very much your advice wer useful:
yes I checked permission of .pg_service.conf file and parent dir, same
thing happens also putting the file in other locations and chown-ing the
file to www-data.
Not sure where QGIS server should log in this configuration (there's a
sysadmin that manage installation in the server i will ask him to make a
separate log)
but I found something in syslog.
It seems that thte variable PGSERVICEFILE is not evaluated.
I've solved commenting the line and putting configuration in the
system-wide pgservice.conf location /etc/postgresql.common
Next step is make GetPrint working... maybe I'll post another question
tomorrow :-)
amefad
Il giorno lun 7 lug 2025 alle ore 23:12 Jorge Gustavo Rocha via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> Hi Amedeo,
> Is the www-data user able to read the pg service file? If you didn't
> change the permissions, /home/ubuntu/.pg_service.conf is only readable by
> ubuntu user.
> Can you check the qgis server logs to see what is going on?
> Best regards,
> Jorge
> Às 21:05 de 07/07/25, Amedeo Fadini via QGIS-User escreveu:
> Errata corrige, the demo project works, the sqlite file was with wrong
> permission.
> Still doesn't load postgis layer
> Amedeo
> Il giorno lun 7 lug 2025 alle ore 21:54 Amedeo Fadini <amefad at gmail.com>
> ha scritto:
>> Hi everybody,
>> I'm upgrading a project based on QGIS server and moved all stuff to new
>> server with Ubuntu 24, QGIS 3.40 LTR postgresql 16.
>> Webserver is nginx, QGIS server is configured on spawn-fcgi with single
>> socket follwing the qgis manual
>> https://docs.qgis.org/3.40/en/docs/server_manual/getting_started.html#spawn-fcgi
>> The project use two layers from postgis, the connection is configured
>> with pg service
>> Connecting on ssh with x.forwarding the project loads without any error
>> and works fine
>> Calling the qgis server getcapabilities or get projectsettings it raise
>> the error
>> <ServerException>Layer(s) not valid</ServerException>
>> Setting QGIS_SERVER_IGNORE_BAD_LAYERS=true getcapabilities works but
>> postgis layer are not published or not showed in Getmap request.
>> Any clue? Where can I find more detailed erro log?
>> even the demo project world.qgs gives balnk image in getmap request. Am I
>> misisng a local Xserver or gui configuration?
>> Below is my nginx conf and systemd/system/qgis-server.service
>> Thank you
>> Amedeo Fadini
>> server {
>> listen 80;
>> server_name <my server name>;
>> location /qgis/ {
>> include fastcgi_params;
>> fastcgi_param SCRIPT_FILENAME /usr/lib/cgi-bin/qgis_mapserv.fcgi;
>> #fastcgi_param QGIS_DEBUG 1;
>> fastcgi_param QGIS_SERVER_LOG_STDERR 1;
>> #fastcgi_param QGIS_SERVER_LOG_LEVEL 0;
>> fastcgi_param QGIS_SERVER_LOG_LEVEL 2;
>> #fastcgi_param PGSERVICEFILE /home/ubuntu/.pg_service.conf;
>> #fastcgi_param QGIS_PROJECT_FILE
>> /home/ubuntu/fiduciali_qgis/fiduciali.qgs;
>> fastcgi_pass unix:/var/run/qgisserver.socket;
>> [Unit]
>> Description=QGIS server
>> After=network.target
>> [Service]
>> ;; set env var as needed
>> ;Environment="LANG=en_EN.UTF-8"
>> ;Environment="QGIS_SERVER_PARALLEL_RENDERING=1"
>> ;Environment="QGIS_SERVER_MAX_THREADS=12"
>> Environment="QGIS_SERVER_LOG_LEVEL=0"
>> Environment="QGIS_SERVER_LOG_STDERR=1"
>> Environment="PGSERVICEFILE=/home/ubuntu/.pg_service.conf"
>> ;Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/world.qgs"
>> Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/fiduciali.qgs"
>> Environment="QGIS_SERVER_IGNORE_BAD_LAYERS=true"
>> ;; or use a file:
>> ;EnvironmentFile=/etc/qgis-server-env
>> ExecStart=spawn-fcgi -s /var/run/qgisserver.socket -U www-data -G
>> www-data -n /usr/lib/cgi-bin>
>> [Install]
>> WantedBy=multi-user.target
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> * Geomaster, LDA *
> * VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC *
> Rua Afonso Palmeira, 31, 7 D
> 4715-278 Braga
> VAT/NIF 510 906 109
> Phone +351 253 257 173
> Site geomaster.pt
> GPS 41.54627, -8.40432
> [image: Logo]
> Jorge Gustavo Rocha
> CTO
> Mobile +351 910 333 888
> Email jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250708/e0ed04f4/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250708/e0ed04f4/attachment-0001.png>
More information about the QGIS-User
