[Qgis-user] Qgis server postgis layers not valid (but desktop works on same machine)
Etienne Trimaille etienne.trimaille at gmail.com
Tue Jul 8 06:08:48 PDT 2025
You should have a warning like this in QGIS Server logs (increase debug
level maybe) :
[WRN] (from Qgis) PostGIS: Connection to database failed
definition of service « name of your service » not found
Next step is make GetPrint working... maybe I'll post another question
> tomorrow :-)
Look at XVFB
https://docs.qgis.org/3.40/en/docs/server_manual/getting_started.html#xvfb
Le mar. 8 juil. 2025 à 10:43, Amedeo Fadini via QGIS-User <
qgis-user at lists.osgeo.org> a écrit :
> Hi jorge,
> thank you very much your advice wer useful:
> yes I checked permission of .pg_service.conf file and parent dir, same
> thing happens also putting the file in other locations and chown-ing the
> file to www-data.
> Not sure where QGIS server should log in this configuration (there's a
> sysadmin that manage installation in the server i will ask him to make a
> separate log)
>  but I found something in syslog.
> It seems that thte variable PGSERVICEFILE  is not evaluated.
> I've solved commenting the line and putting configuration in the
> system-wide pgservice.conf  location /etc/postgresql.common
> tomorrow :-)
> amefad
> Il giorno lun 7 lug 2025 alle ore 23:12 Jorge Gustavo Rocha via QGIS-User <
> qgis-user at lists.osgeo.org> ha scritto:
>> Hi Amedeo,
>> Is the www-data user able to read the pg service file? If you didn't
>> change the permissions, /home/ubuntu/.pg_service.conf is only readable by
>> ubuntu user.
>> Can you check the qgis server logs to see what is going on?
>> Best regards,
>> Jorge
>> Às 21:05 de 07/07/25, Amedeo Fadini via QGIS-User escreveu:
>> Errata corrige, the demo project works, the sqlite file was with wrong
>> permission.
>> Still doesn't load postgis layer
>> Amedeo
>> Il giorno lun 7 lug 2025 alle ore 21:54 Amedeo Fadini <amefad at gmail.com>
>> ha scritto:
>>> Hi everybody,
>>> I'm upgrading a project based on QGIS server and moved all stuff to new
>>> server with Ubuntu 24, QGIS 3.40 LTR postgresql 16.
>>> Webserver is nginx, QGIS server is configured on spawn-fcgi with single
>>> socket follwing the qgis manual
>>> https://docs.qgis.org/3.40/en/docs/server_manual/getting_started.html#spawn-fcgi
>>> The project use two layers from postgis, the connection is configured
>>> with pg service
>>> Connecting on ssh with x.forwarding the project loads without any error
>>> and works fine
>>> Calling the qgis server getcapabilities or get projectsettings it raise
>>> the error
>>> <ServerException>Layer(s) not valid</ServerException>
>>> Setting QGIS_SERVER_IGNORE_BAD_LAYERS=true getcapabilities works but
>>> postgis layer are not published or not showed in Getmap request.
>>> Any clue? Where can  I find more detailed erro log?
>>> even the demo project world.qgs gives balnk image in getmap request. Am
>>> I misisng a local Xserver or gui configuration?
>>> Below is my nginx conf and systemd/system/qgis-server.service
>>> Thank you
>>> Amedeo Fadini
>>> server {
>>>     listen 80;
>>>     server_name <my server name>;
>>>     location /qgis/ {
>>>         include fastcgi_params;
>>>         fastcgi_param SCRIPT_FILENAME /usr/lib/cgi-bin/qgis_mapserv.fcgi;
>>>         #fastcgi_param  QGIS_DEBUG              1;
>>>         fastcgi_param QGIS_SERVER_LOG_STDERR 1;
>>>         #fastcgi_param QGIS_SERVER_LOG_LEVEL 0;
>>>         fastcgi_param QGIS_SERVER_LOG_LEVEL 2;
>>>         #fastcgi_param  PGSERVICEFILE /home/ubuntu/.pg_service.conf;
>>>         #fastcgi_param  QGIS_PROJECT_FILE
>>> /home/ubuntu/fiduciali_qgis/fiduciali.qgs;
>>>         fastcgi_pass  unix:/var/run/qgisserver.socket;
>>> [Unit]
>>> Description=QGIS server
>>> After=network.target
>>> [Service]
>>> ;; set env var as needed
>>> ;Environment="LANG=en_EN.UTF-8"
>>> ;Environment="QGIS_SERVER_PARALLEL_RENDERING=1"
>>> ;Environment="QGIS_SERVER_MAX_THREADS=12"
>>> Environment="QGIS_SERVER_LOG_LEVEL=0"
>>> Environment="QGIS_SERVER_LOG_STDERR=1"
>>> Environment="PGSERVICEFILE=/home/ubuntu/.pg_service.conf"
>>> ;Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/world.qgs"
>>> Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/fiduciali.qgs"
>>> Environment="QGIS_SERVER_IGNORE_BAD_LAYERS=true"
>>> ;; or use a file:
>>> ;EnvironmentFile=/etc/qgis-server-env
>>> ExecStart=spawn-fcgi -s /var/run/qgisserver.socket -U www-data -G
>>> www-data -n /usr/lib/cgi-bin>
>>> [Install]
>>> WantedBy=multi-user.target
>> QGIS-User mailing listQGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> * Geomaster, LDA *
>> * VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC *
>> Rua Afonso Palmeira, 31, 7 D
>> 4715-278 Braga
>> VAT/NIF 510 906 109
>> Phone   +351 253 257 173
>> Site geomaster.pt
>> GPS 41.54627, -8.40432
>> [image: Logo]
>> Jorge Gustavo Rocha
>> CTO
>> Mobile   +351 910 333 888
>> Email    jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250708/2de49009/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250708/2de49009/attachment-0001.png>
More information about the QGIS-User mailing list
